splitrivet
posted on 26/1/04 at 01:12 PM |
Roll bar diameter
Bit of a stoopid question I know but what diameter tube have you guys used for a roll bar.
Reason is I scrounged some 1 3/4 inch dia 1/8 wall tube (they didnt have any 2 inch) just long enough to bend a roll bar out of,would this be meaty
enough for a roll bar.
Not that Im planning on rolling the car you understand.
Bob
dozracing
posted on 26/1/04 at 01:18 PM |
Thats more than plenty. Thats heavier stuff thant he MSA motorsports body require for a race hoop.
Kind regards,
Darren
splitrivet
posted on 26/1/04 at 01:20 PM |
Thanks Darren
Bob
jonti
posted on 26/1/04 at 09:53 PM |
sindes a bit skinny fer meh yooth
marns abite tiw an a hafe ah think.
cosner find a birra dinespite ?
tha nehds a birra good stuff told it of thee yed when theet upside dine tha nowst !
Seriously ....our kids got an ex Toyota Hilux roll bar goin cheep in Tunstall if it'll mod.......dunno if it will but it might......if
you're interested I'll have closer look for you.
[Edited on 26/1/04 by jonti]
OFROK
type 907
posted on 27/1/04 at 12:08 AM |
Hi
Just looked it up in the SVA book.
It says, "For guidance ideally should be made from CDS, 45mm x 2.5 wall or 50mm x 2mm wall. "
Hope this helps.
Paul G
Too much is just enough
craig1410
posted on 27/1/04 at 01:20 PM |
Doz,
Are you sure about the MSA regs. I thought that the figures in type 907's posting were based on the MSA recommendations and thus 45mm x 2.5mm
was the minimum CDS tubing allowed. 1.75" is marginally under 45mm (44.45mm I make it) and although common sense tells me that the extra 0.5mm
wall thickness will make up for this, I don't know how rigidly the MSA would apply this rule.
Also, be aware that the amount of ovalisation must be controlled when bending the tubing for MSA rules. I think it has a limit of 90% minimum normal
diameter at the narrowest part of the bend.
All this is for MSA though so if you want to run on the road just make sure that doesn't have any sharp edges. If you are planning to attach
your seatbelts to it then you may want to make it MSA compliant and then hopefully this will more than please the SVA man. I believe backstays are
required for seatbelt attachment but this is the topic of some debate...
My home made rollbar is just made from black pipe but it is 48mm diameter and 2.8mm thick. I did some sums at the time and even taking account of the
difference in strength between black pipe and CDS this is roughly the same strength as a 50mm x 2mm piece of CDS. I'm not planning to race it so
this is fine IMHO. I also added backstays made out of 16swg x 38mm tubing but these are more for cosmetic effect rather than strength and my seatbelts
will attach to the chassis not the rollbar.
Craig.
jonti
posted on 27/1/04 at 01:22 PM |
Yep ..just checked and mine's 50mm
Checked the Toyo one and that's 75mm so ...might be a bit thick.
OFROK
twentyover
posted on 1/2/04 at 07:34 PM |
Depends on the material. If ERW tubing, there are constraints about eher the seam should be placed. I seam (ok, poor play on words) to recall the weld
line needs to be dead on the inside radius of the bends in the hoop. DOM or CDS have no apparent seam, so are relayively unconstrained
craig1410
posted on 1/2/04 at 07:45 PM |
Twentyover,
I bent mine with the seam along the curve as I thought this would have less chance of tearing. To clarify, my seam is neither on the outside or inside
of the bend, it is 90 degrees with respect to both. By the time it is prepared and painted it should be impossible to tell where the seam was
anyway!
I guess your comments were motorsport related anyway as the rollbar isn't required for road use.
Craig.
splitrivet
posted on 2/2/04 at 04:26 PM |
Arses looks like I'll have to buy some tube then,bent it with the seam on the inside simply so I had a datum for the bend.
Mind you is a roll bar an SVA requirement or is it if ones fitted its gotta be x inches in diameter.
Dust now wot I mean Jonti ar wost wine anyroad.
Bob
By the way is that Toyota pick up up for sale, after one, gotta be much cheapness tho
[Edited on 2/2/04 by splitrivet]
craig1410
posted on 2/2/04 at 09:13 PM |
Splitrivet,
Don't assume that I am correct, I was half expecting someone to jump in and say that I was talking nutsack (I bet they can't resist
now...)
Can anyone confirm where the seam on ERW should be when you bend it?
Craig.
jonti
posted on 3/2/04 at 02:23 PM |
[Originally posted by splitrivet
Bob
Don't think (in fact I'm pretty sure) its not required for SVA....
Only have Toyota Roll Bar mate....not the vehicle......Ring Jeremy Clarkson..he's got one I think, although it may need a bit of bodywork
Tha' twine were orrite. weh drunk eet anna nuther one an gorra bit wobbly ....its nehw good onna Sundee neht nehter !!!.....me yed were thumpin
lark a stehm ammer inth moanin !
I'm sure these other chaps haven't the slightest clue what we're talking about
old boy.
OFROK
posted on 3/2/04 at 02:52 PM |
old boy.
I can assure you that we have not the slightest interest in this authentic frontier gibberish!
splitrivet
posted on 3/2/04 at 04:51 PM |
Ar oop ere wir a mons a mon an shape git nirvus.
Think I'll just leave it as is then, ah well I can hear you all say, if the car rolls and you become a paraplegic dont come running to us.
cheers,
Bob
jonti
posted on 3/2/04 at 05:42 PM |
Frontier Gibberish ?!!!!!.... How dare you sir ?........I'll have you know this is authentic Potteries gibberish being gibbered by two
accomplished exponents of the art..
.. bet thee cosna see...cost kick a bow agen a woa an yed it with thee ed till it bosts ?.............cost ?
OFROK
Spyderman
posted on 4/2/04 at 01:41 PM |
Erm, I think the word is,
BOLLOX
Spyderman
200mph
posted on 4/2/04 at 02:06 PM |
Craig, the seam on my roll bar from luego is on the side, so i suppose depending on mounting it could be either the front or the back, not the insife
or outside if you get me
Mark
jonti
posted on 4/2/04 at 05:05 PM |
BOLLOX
Inarticliate peasant! ..........Dont you know you spell BOLLOX wiva K ?
Its ..........BOLLOWKS !!!......... dear boy
You going to come to Splitrivet's proposed North Staffs Gathering ?
[Edited on 4/2/04 by jonti]
OFROK
craig1410
posted on 4/2/04 at 09:27 PM |
Mark,
Yes that is the same with mine and in my case the seam is towards the back of the car. Hopefully this is the way it should be... I'm sure I read
somewhere that it is the correct way to bend seamed tubing.
Craig.
Simon
posted on 5/2/04 at 12:57 AM |
Just thought I'd have a look at mine, to see where the seem is
Guess what. There ain't one.
Hope this helps
Simon
200mph
posted on 5/2/04 at 09:43 AM |
Well I wouldnt imagine luego would be ballsing up a thing like a roll bar?
Otherwise half my car might fall apart
Mark
twentyover
posted on 26/2/04 at 09:49 PM |
Craig-
Sorry for the long time from last post- been away from a computer.
First, I was commenting on ERW tubing based on SCCA GCR's (General Competition Rules) which pretty much dictate design of saftey equipment for
amatur racing in the US.
It's been a couple years since I last looked, but IIRC the seam was to be located in the inside radius of the bend. But it's been a couple
years.
You're correct, though, if this is a street application, there's no need to subscrivbe to competition rules. When I make roll bars,
whether street or race, I always subscribe to SCCA rules, as you never know when you maight want to convert it to a racer, and nothing pains me more
then cutting out an existing cage (I know, I've done it) to replace it with one that complies with requirements.
