Author: Subject: GRP v Ali
posted on 16/12/08 at 02:57 PM Reply With Quote
GRP v Ali
Assuming you have a buck ready and the necessary tools, but are a beginner at both disciplines... then what's the easier of the 2 body-making techniques?
For some reason, I think I would be better at cutting / shaping / welding ali sections, than I would with laying GRP, but that's not based on anything!
Opinions appreciated from those in the know!
Humbug
posted on 16/12/08 at 03:01 PM Reply With Quote
Is it different from Frazier vs Ali?
Mr Whippy
posted on 16/12/08 at 03:05 PM Reply With Quote
grp easiest
panel beating and ali welding are not easy
both are quite expensive
posted on 16/12/08 at 03:12 PM Reply With Quote
Also assuming strength for strength... what would be the lighter material?
mcerd1
posted on 16/12/08 at 03:17 PM Reply With Quote
alloy would probably be lighter than wet layup GRP
posted on 16/12/08 at 03:23 PM Reply With Quote
Cheers!
I think it's the mess-element of GRP that's putting me off!
mcerd1
posted on 16/12/08 at 03:37 PM Reply With Quote
I thought you'd be going for prepreg carbon - thats much lighter and stronger
Mr Whippy
posted on 16/12/08 at 03:38 PM Reply With Quote
Originally posted by scootz
Cheers!
only if your a messy worker
omega0684
posted on 16/12/08 at 03:58 PM Reply With Quote
i would just buy the panels, if you are making everything else, why not treat yourself.
mcerd1
posted on 16/12/08 at 04:03 PM Reply With Quote
a certain member of this forum might do prepreg carbon or glass for you if you ask him nicely
[edit] (I don't mean me - he's at the other end of the country )
[Edited on 16/12/08 by mcerd1]
pewe
posted on 16/12/08 at 04:33 PM Reply With Quote
GRP every time - no contest if you haven't done either before.
IMHO GRP is much easier to work, much more forgiving if you make minor mistakes and easier to repair if ever that's necessary.
Try some small items first and I'll guarantee you'll never look back.
I made my bonnet bulge using cardboard and tank tape for the buck, then plaster-of-paris and builders scrim to make the mould. Release agent was candle-wax poured inside the mould before laying it up.
HTH.
Cheers, Pewe
posted on 16/12/08 at 05:09 PM Reply With Quote
Cheers!
posted on 16/12/08 at 07:30 PM Reply With Quote
Just remember that
a) the resin stinks - you won't believe how far the stink will travel, and how long it lasts.
b) some people can be allergic to the resin - you really must wear gloves.
Apart from that - it's not a hard thing to do, but it can be frustrating, e.g. when your work gets stuck into your nice new mould, and you just KNOW that the mould is going to be useless when you finally get it out!
Hugh Paterson
posted on 17/12/08 at 06:24 PM Reply With Quote
If u take a plod through to weegie land one weekend I will show u how to do the grp stuff its a doddle
Shug
