chris_smith
posted on 18/12/08 at 08:28 PM |
how much primer and paint?
following on from my last post - linky
how much etch primer ans paint do i need to do the whole car i was looking at a litre of each or am i getting to much/not enough?
cheers
chris
maartenromijn
posted on 18/12/08 at 08:43 PM |
Normally you can read the consumption per sqare meter on the can. Do the maths, and take into account that the spray installation needs a sip as well.
BLOG: http://thunderroad-super7.blogspot.com/
Danozeman
posted on 18/12/08 at 09:13 PM |
Im currently spraying mine with cellulose. The paint thins 50/50 when spraying in a gun so youl get 2 litres of paint. So 1 litre of each should do
it.
Im not spaying the sides of mine yet and looks like i will deffo have enough left to do the sides if/when i decide to do them.
Depends if u want spare left of the same mixed colour should u need it later on aswell.
Dan
mark chandler
posted on 18/12/08 at 09:40 PM |
For myself:
1/2 litre of etch for the ali bits.
1 litre high build primer for everything
2 litres top coat
As it winter get some fast thinners.
You will need to prime the etch primer if you see what I mean.
Regards Mark
tootall
posted on 18/12/08 at 10:56 PM |
etch is only needed on bare metal and fiber glass and u only need one light coat of it then a few coats of primer surficer or thined out high build 1
litre would be fine and depending what colour your painting and colour of your primer about 1 or 2 litres of top coat with some spair so u can touch
up incase u bump it atall.
remember most paint suplyers are going water base on 1st jan so get ya colour u need asap
some people dream of sucsess, others just get on and do it !!
