smart51
posted on 28/12/08 at 04:47 PM |
how do you cut a nice radius onto a sharp edge
I'm making all my bodywork with sharp edges that I will then cut a 3mm radius on before painting. I've either sanded the filler flat or
have been generous with the gelcoat in the corners to there is enough material to cut in to. How do you cut a nice constant radius onto an edge? I
could use sand paper by hand but the radius would change all along the edge.
posted on 28/12/08 at 04:55 PM |
maybe an electric sander to help you get it even?
i mean the vibrating random orbit sort...
[Edited on 28/12/08 by JoelP]
blakep82
posted on 28/12/08 at 05:22 PM |
perhaps (never tried myself) sand the corner you want into a block of wood, and use that as a sanding block?
________________________
mr henderson
posted on 28/12/08 at 05:34 PM |
If you can get a hand held 1/4" router on to it, you can use a bearing guider 3mm radius roundover bit.
Alternatively just sand it by hand and use your fingers to feel for any discontinuities
John
Fred W B
posted on 28/12/08 at 05:44 PM |
I make steel templates/checking plates with the radius I want - drill a hole the diameter you want, and cut it open, file it square.
Pu a guide coat of paint on and sand with a block, checking with the template, which you can also use as a scraper to put the edge on. Soon you get
the hang of it, and can work mainly by "eye", just checking occasionally. You will see a straight line appear at the start of the radius
in the guide coat you are sanding off.
I prefer to do this work by hand, one slip with a power tool and you ruin the edge/radius
Fred W D
[Edited on 28/12/08 by Fred W B]
Fred W B
posted on 28/12/08 at 06:00 PM |
I went and took a couple pics to illustrate. Hope this helps
Fred W B
temp 1
temp 2
John Bonnett
posted on 28/12/08 at 06:14 PM |
A method I cribbed from Craig Seymour's very informative website http://craigsphoenix.se7ens.net/.
Drill a 6mm hole in a piece of stainless steel sheet and slice it across its diameter. You then have the correct radius. You can use this tool as a
scraper to put the radius on the sharp edge.
hth
John
YQUSTA
posted on 28/12/08 at 06:17 PM |
if you have a router you could put a cut in it so the sand paper fits that would give the same as above but would be as long as you like.
chrsgrain
posted on 28/12/08 at 07:11 PM |
I would have gone for the router - but it sounds like Fred has got it sorted - by the way Fred - where is the latest update on your bodywork - we all
like to see your work...
Chris
Fred W B
posted on 28/12/08 at 07:33 PM |
Thanks Chris - Look down a few posts in this section? I did an update on the 22nd
Fred W B
