Author: Subject: Stone Guards
cerbera
posted on 23/1/09 at 10:00 AM Reply With Quote
Stone Guards
Got some new stone guards and want to stick them on rather than rivet.
What is out there that will be good enough for the task and, if I want, can be removable without damaging the rear wings?
Mr Whippy
posted on 23/1/09 at 10:12 AM Reply With Quote
Velcro?
why not make them permanent and just unbolt the wing stays...
[Edited on 23/1/09 by Mr Whippy]
posted on 23/1/09 at 10:39 AM Reply With Quote
if the stone guards are metal, then very likely they will get bent if you try to remove glued on ones.
I used stainless steel M4 button head screws - as permanent as rivets or glue but removable too.
cerbera
posted on 23/1/09 at 11:05 AM Reply With Quote
They are the plastic carbon fibre effect type and don't really want to drill holes in the rear wings in case I decide to remove them at a later date, which is why Im searching for other means of attachment.
Dont want to driving round with rear wings full of holes.
[Edited on 23/1/09 by cerbera]
omega0684
posted on 23/1/09 at 11:20 AM Reply With Quote
i got the moulded carbon fibre effect ones and just used the same stuff that i used to stick the floor panels on with. wurth adhesive!
posted on 23/1/09 at 05:34 PM Reply With Quote
Our carbon fibre stoneguards are stuck on with double sided adhesive foam strip.
Phil
dhutch
posted on 23/1/09 at 06:43 PM Reply With Quote
A small bead of sikaflex (or simular) around the edge.
- Stuck firm, no chafing, no much stuck behind it, do damage to the wing. And if its a small enough bead, with care, you could be able to it off too.
Daniel
