hobzy
| posted on 5/2/09 at 01:12 PM |
tonneau/half cover dimensions
Can anyone show me some pics of their tonneau covers and some rough dimensions? I have got hold of some waterproof vinyl and fancy a go at making my
own; something like this from softbitsforsevens:
| posted on 5/2/09 at 01:43 PM |
It'll vary a lot from car to car and make to make.....
jlparsons
| posted on 5/2/09 at 02:09 PM |
Top tip that was given to me - make it from scrap fabric first to check fit, but don't use any scrap that'll stretch (ie old bed sheets)
cos that'll convince you it's going to fit when in fact it might not! I've heard of a couple of folk getting burnt like that.
Will be very interested to see the results. A usable soft/hard top to make these cars all-weather is the only thing they're missing in my
opinion. Best of luck!
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
| posted on 5/2/09 at 02:39 PM |
I'm interested in a one as well. One with half doors and slits down the middle to keep the wind off.
| posted on 5/2/09 at 03:36 PM |
It's definately worth making a pattern first out of some cheap material. I used some lining material first. Non stretchy, reasonably cheap and
easy to cut.. Being cream (typically) it's also easy to draw on with a marker pen....
hobzy
| posted on 5/2/09 at 06:50 PM |
I know. I was sort of fishing for someone with an Indy
I was told today by our textiles lass at work to use card first as its easy to draw on and stick to the car, then make a rough from that in an old
sheet or something to check the seams, then go for it.
Can't decide whether to use velcro or zips - want to do seperate half doors and the top in 2 halves...
Don't mind sharing the pattern after its done. The vinyl only cost £25, so not too fussed if it doesn't look good - can always have
another go.
Another question - which fastenings to go for on the bodywork?
hobzy
| posted on 6/2/09 at 09:47 AM |
Nice one! Might take you up on that if i get stuck! Cheers.
Are they just pop fasteners?
zetec
| posted on 6/2/09 at 11:29 PM |
I made a pattern using very heavy lining paper (wallpaper) once I got started I fitted the from scuttle section, then tensioned by fixing at the rear
and finished up doing the sides. I used press studs fitted to the body with small nuts/bolts. Takes about 20 secs to fit and designed to stop the rain
if caught out and about. The material is lightweight, waterproof and folds up very small. I sewed strips of vinyl into the seams fitted with studs to
give extra strenght.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
hobzy
| posted on 7/2/09 at 12:30 PM |
Brilliant. Thanks for the replies so far. Very helpful... I have an aeroscreen, i'm just wondering how to fit round where it meets the
scuttle/dash...
Meeerrrk
| posted on 9/2/09 at 01:34 PM |
thats awsome, fancy making me one?!
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
zetec
| posted on 9/2/09 at 06:03 PM |
Sorry mate too much mucking about, would be a poor man if I made them for a living!
Meeerrrk
| posted on 9/2/09 at 06:10 PM |
lol only kidding; great job tho, fair play to ya
hobzy
| posted on 9/2/09 at 08:35 PM |
Made up the patterns for the sides and top this weekend. Much easier with the lining paper - nice call on that. Going to do a trial run with an old
sheet Anyone with an MK can have the paper pattern once I'm done for postage providing it turns out looking alright
