myke pocock
posted on 14/2/09 at 04:53 PM |
SVA comments required
Thanks for the comments on my first picture posted today so here is another. The edge of the exhaust exit hole and air filter hole in the bonnet are
now protected. The alloy plates on the dash top are to cover the demist slots when I fit a full screen and are radiused to over 2.5mm . Anything else
look likely to cause a problem?
Dangle_kt
posted on 14/2/09 at 05:01 PM |
picture doesnt work mate
myke pocock
posted on 14/2/09 at 05:05 PM |
Posted it exactly as I did earlier in the day and it opens up for me OK. So????? dont know what the prob is.
pewe
posted on 14/2/09 at 05:11 PM |
To save any confusion over the aero-screen why don't you just remove it for SVA and then replace it afterwards? Worked for me.
Cheers, Pewe
myke pocock
posted on 14/2/09 at 05:16 PM |
Problem is, without the screen the uprights are quite flexible. Wouldnt that cause an issue with the tester?
blakep82
posted on 14/2/09 at 06:04 PM |
remover the uprights
________________________
blakep82
posted on 14/2/09 at 06:11 PM |
theres only the 1 picture of the car (*the original one you poster earlier today) on your photobucket account it seems?
myke pocock
Cant, mirrors fitted to them.
myke pocock
posted on 14/2/09 at 06:21 PM |
Hope this works!!!
bigpig
posted on 14/2/09 at 07:13 PM |
Looks nice.
Possibly the air filter needs a second glance over and maybe edgining on the tunnel side pannels.
I love what you have done with the lights and switches on the tunnel. Never even thought of doing it that way, looks really good.
posted on 14/2/09 at 07:45 PM |
Just remember - the worst that can happen is that you end up with a list of things to fix from the SVA. It's obvious that you've made a
very good effort, so the tester will be reasonable with you.
I think that there are dodgy areas that may need fixing - but you're not far away.
chrisg
posted on 14/2/09 at 07:55 PM |
I think you might have a problem with the air filter radius, it doesn't look to have a big enough radius on the top edge.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Schrodinger
posted on 16/2/09 at 11:36 AM |
Could also need a bit of edging around the exhaust through the side of the car.
Keith
Aviemore
