Author: Subject: Bonding Carbon Fibre to Ali
londonsean69
posted on 3/4/09 at 06:22 PM Reply With Quote
OK, so a litle idea popped into my head - which is probably a bad thing.
I would quite like a bit of carbon on the car, mainly for looks, rather than any weight saving ability.
I would also like to have it where I can look lustfully at it's brilliant technologically advanced form, so am thinking of the transmission tunnel.
So as to avoid having to get into all this mould making nonsense, complete with vacuum bagging etc. I am thinking of bonding a layer or 2 of CF onto a (slightly thinner than normal) aluminium panel.
It wouldn't be vacuum bagged, and I'm not too bothered about a little extra epoxy, because that (should) mean extra glossy finish.
Anybody done anything similar?
I have read on t'interweb that there is a possibility of galvanic corrosion between the 2, but this can be prevented with a thin (40gm) layer of GRP, or a few decent coats of etch primer.
Any advice gladly appreciated
Sean
Keith Weiland
posted on 3/4/09 at 06:30 PM Reply With Quote
Why not just buy some CF sheet and get rid of the ally completely?
Hammerhead
posted on 3/4/09 at 06:35 PM Reply With Quote
two words - galvanic corrosion
Colnago_Man
posted on 3/4/09 at 08:24 PM Reply With Quote
Bang on! Discovered the effects of it this afternoon while trying to remove a very expensive carbon fibre seat post from an alumium bike frame!
londonsean69
posted on 3/4/09 at 08:33 PM Reply With Quote
I thought abou this, but mostly because people like carbon mods etc. want silly money for sheets.
£107 for 1 Sq. M, there will be wastage etc.
it's about £28 for 1 Sq. M of carbon fabric, obviously there is the cost of the resin and ally on top of that, but a lot less wastage.
I know they are super cool pre-preg (although the above price was for wet lay-up) and stuff, but it's a lot of dosh.
I may also do a carbon/ally dash, and if it all works well various other parts, which might not be totally flat.
Very helpful, I will refer you to the 30 or so words I wrote regarding this in the original post
Sean
twybrow
posted on 3/4/09 at 09:00 PM Reply With Quote
Abraid the aluminium, making sure you take off any oxidsed material. Abraid the CF. Degrease both, then bond with your favoured glue. PU works well as long as the Al is very well keyed. Epoxy would be good (Araldite etc).
I have a CF dash, tunnel, boot, airbox etc (I play with CF for a living), with no major problems bonding bits together as long as you prep well. As you have already said, a thin layer of glass (or the adhesive you are using) will help to protect from galvanic corrosion. I hope this helps.
catman
posted on 3/4/09 at 09:08 PM Reply With Quote
its not on there web site but carbon mods now do self adhesive real cabon sheets, they are flexible to, so one single seamless sheet will do the job
Ed
caged supersix
Carbon/GRP
210 bhp silvertop
190 lbft
omega0684
posted on 3/4/09 at 10:04 PM Reply With Quote
how does Galvanic corrosion occur between aliminium and CF? i thought that galvanic corrosion occurred between two metals in contact when sub merged in electrolyte
"Galvanic corrosion is an electrochemical process in which one metal corrodes preferentially when in electrical contact with a different type of metal and both metals are immersed in an electrolyte"
londonsean69
posted on 4/4/09 at 10:53 AM Reply With Quote
Ahh, sensible answers.
@twybrow
I'm actually planning on doing a wet layup direct onto the aluminium, rather than gluing a sheet of ready cured CF down.
@catman
The thing with a stick on sheet, is it won't provide any structural strength.
I know I want it mainly for looks, but if I can go down a thickness in ally then it's all good.
Certainly an option I would condiser though.
@Omega
Well, because CF is conductive maybe that has somethin to do with it.
I am still stuggling to see why or how it would happen, and even if it did, eventually all the ally would be eaten away, then I could put another layer of CF on the inside and have a full CF panel.
Although that would probably take 10 years or something
Sean
twybrow
posted on 4/4/09 at 07:52 PM Reply With Quote
If you are wet laying onto Alu, then just start with a layer of glass. The other problem I see, is the surface finish you get. It will take a lot of sanding and laquering to get an A1 finish. Maybe you could cheat, by pressing a mould released sheet of glass (a mirror or similar) onto the wet CF, to act as a basic mould face....
