posted on 7/4/09 at 07:40 PM |
Argghhh! I hate bodywork. HELP!
Right then, me bonnets been in a crash and fell over a couple a times, then 2 weeks ago blew away and crashed onto the road...
Well got some wet n dry and gently rubbed them out, seemed to do the trick, polished the areas ( and the rest) with Autoglym Super Resin stuff.
Now got flat matt areas instead of scratches...
How do I get the shine back on please??
Danozeman
posted on 7/4/09 at 07:47 PM |
Try to buff them back with some sort of cutting compound like G3.
Super resin is just polish and wont cut them back and smooth them off.
G3 should do it.
What grade wet and dry did u use. U need at least 800 then G3 then super resin.
Dan
Gary 7
posted on 7/4/09 at 07:48 PM |
Have you tried t cut,if the scratches are out it should bring the shine back.
posted on 7/4/09 at 09:14 PM |
It was 600 grade, the highest B&Q had, I'll go back to Halfords for some G3.
stevebubs
posted on 7/4/09 at 09:20 PM |
farecla g3 then g10 and plenty of elbow grease
DavidW
posted on 7/4/09 at 09:37 PM |
I've had good results with this. I think I had some 1200 wet and dry too.
austin man
posted on 7/4/09 at 10:35 PM |
use some 800 then 1000 or 1200 followed by a tcut and polish with the autoglym. I am a believer in autoglym having used it a few times it does have a
sligh cutting action.
Ps remember to rub in circles. The above method can also be used to remove scratches in perspex
Simon
posted on 7/4/09 at 10:52 PM |
Or use an electric polisher. Carefully
Simon
stevebubs
posted on 7/4/09 at 11:34 PM |
Please don't get your sandpaper from B&Q....most of it is crud for working on car bodywork.
Halfords is more expensive but works...and they go up to 2000 grade if you go on the right day...most of the time they max at 1200 though....
stevebubs
Simon
If using an electric polisher keep the mop damp
Agriv8
posted on 8/4/09 at 06:26 AM |
G1200 followed by
G2000 followed by
g3 cutting compound followed by
G10 cutting compound followed by
wankers cramp ! followed by
buying a 4000 rpm electirc polisher with mops from ebay
Trust me black shows imperfections !!1
Regards
Agriv8
smart51
posted on 8/4/09 at 07:20 AM |
When polishing perspex, I found that tooth paste reduced the haze after I'd used cutting paste. It also left the surface minty fresh.
posted on 8/4/09 at 09:32 AM |
I used autosol to do my GRP cos it was the only cutting type paste I had handy. Did the job very nicely too!!! Plenty of elbow grease and job's
a good'un.
posted on 8/4/09 at 10:55 AM |
quote: Originally posted by Agriv8
G1200 followed by
G2000 followed by
Regards
Agriv8
Gorden Bennet, I aint got shares in Halfords you knows...
And, does polishing bodywork really turn u on that much? or does the cock custard work as good as G3?
[Edited on 8/4/09 by coozer]
Triton
posted on 8/4/09 at 06:18 PM |
polishing gel is a pain in the 'arris especially yellow as easy to turn it into a kinda of burnt orange if you are not paying
attention....wonder how i found that out
go thru the grades of wet n dry finishing with as fine a paper as you can get. I use g6 which is a quite a course cutting paste with lots of water to
keep things cool, but it makes a right royal mess of everything around you...
Silverline do polishers for about £40 and mine has been zapped everyday for 6 months and no problems apart from used 3 lambswool heads at £25 a
thro!!!.
www.tritonraceseats.com
www.hairyhedgehog.com
