Author: Subject: Painting Aluminium
dave1888
posted on 12/4/09 at 08:46 PM Reply With Quote
Painting Aluminium
Do you have to use a acid etch primer everytime or can i get away with keying the surface.
tilly819
posted on 12/4/09 at 09:07 PM Reply With Quote
You really have to use an etch primer, if you dont the paint apear to stick but over time will just fall off
hope this helps
tilly
posted on 12/4/09 at 09:10 PM Reply With Quote
I'd certainly use acid etch. I've used paint-on "special metal primer" in the past which is better than nothing but realistically it's a no-brainer. Acid-etch (Upol ? number 8) for me each time.
