Author: Subject: Modifying Bonnet
Dave Bailey
posted on 16/4/09 at 07:24 PM Reply With Quote
Modifying Bonnet
Looking for some advice about modifying my bonnet. I have one of the old Luego kits and the panels basically fit where they touch. The Front edge has a small piece of damage which will need repairing anyway. I would like to extend the leading edge of the bonnet then sand down to get a good shut line. The air intake on the front edge also needs adjusting because it is a little distorted. What would be the best way to make a permanent repair? Final thing will be to paint the bonnet. The colour is black so will show up everything.
thanks
Dave B
jacko
posted on 16/4/09 at 08:07 PM Reply With Quote
If i was doing it i would grip a piece of thin alloy about 75mm wide around the front of the bonnet sticking out say 25mm at the front .
Then use fiber glass resin and matting to build the front up, add some black paint in the resin it helps build up the colour [ only a small amount of paint
ps put the alloy on the outside of the bonnet
