Author: Subject: the finished article
chris_smith
posted on 17/5/09 at 06:18 PM Reply With Quote
finally finished the painting and put her back together all i need now are my plates and im ready to get on the open road
chris
[Edited on 17/5/09 by chris_smith]
omega0684
posted on 17/5/09 at 06:46 PM Reply With Quote
what happened to the OSR wheel arch?
mangogrooveworkshop
posted on 17/5/09 at 07:00 PM Reply With Quote
put some mud flaps on the front........trust me it will be the best thing you do.....other wise your baby blue will be stone chip black.
Had mine out for a bit and its filthy....but then again its done 1500 miles in the last few weeks.
Its first legal run was 750 miles
Dangle_kt
posted on 17/5/09 at 07:04 PM Reply With Quote
HEEEEYYYYYYY!
Great stuff!
You must be thrilled, it's turned out really nice mate!
Did you use that rear panel in the end? If so it looks good with the paint job.
Once your on the road drop me a u2u if you don't mind an excited passenger? I'd love a bit of encouragement prior to getting mine on the road.
Andrew
mark chandler
posted on 17/5/09 at 07:05 PM Reply With Quote
Very smart.
Blue seems to have richened up from your previous post.
chris_smith
posted on 17/5/09 at 07:14 PM Reply With Quote
not sure what your referring to Omega
Did you use that rear panel in the end? If so it looks good with the paint job. Once your on the road drop me a u2u if you don't mind an excited passenger? I'd love a bit of encouragement prior to getting mine on the road.
Andrew, yes thats the very same rear panel Thank you so much, its not quite a perfect fit but it will certainly do, ill be over to take you for a spin no probs as soon as those plates are on
last post were phone pics these are digi cam pics so it is a true reflection of the colour and its outside so proper light so to speak
was certainly on my mind, should also stop the boulders being embedded in my head as happened on sva trek
cheers
chris
omega0684
posted on 17/5/09 at 07:17 PM Reply With Quote
in your last photo the OSR wheel arch is lower than the boot tub floor,is it supposed to be lower than the boot floor?
[Edited on 17/5/09 by omega0684]
chris_smith
posted on 17/5/09 at 07:25 PM Reply With Quote
it is the same on both sides, all the parts have been bought/given from here there and everywhere and none of the parts are a match so iv done the best i can with the parts to hand, to get the arches to "look right" then thats the position i found looked better, i think it looks good and am happy with the result considering the mismatch of pieces/parts
cheers
chris
eccsmk
posted on 17/5/09 at 07:33 PM Reply With Quote
that looks spot on!!
loving the blue
Dangle_kt
posted on 17/5/09 at 07:42 PM Reply With Quote
cheers
chris
I think it looks fine, as long as it matches which it does.
