Author: Subject: Plastic petrol tank leak
b4ldd
posted on 25/5/09 at 04:38 PM Reply With Quote
Hi
I have a leak in a MK petrol tank its at the top where the plate has been put in to take the sender (not fitted) it appears that the joint is leaking when full. Whats the best thing to seal it
Charlie
adithorp
posted on 25/5/09 at 08:00 PM Reply With Quote
Cork or neoprene gasket. Deffo not silicone sealant.
adrian
http://jpsc.org.uk/forum/
b4ldd
posted on 25/5/09 at 09:05 PM Reply With Quote
Its a plastic welded joint
Marcus
posted on 26/5/09 at 11:38 AM Reply With Quote
Don't seal it, replace it!!!
A while ago MK had some plastic tanks made which were welded with the wrong filler, it has been well documented here. How old is your tank?
I would suggest a call to MK as they were replacing plastic tanks with ally ones.
Is your car SVA'd? If not, the plastic tank wouldn't pass IVA now, they need a certificate.
Marcus
Because kits are for girls!!
mad-butcher
posted on 26/5/09 at 06:40 PM Reply With Quote
Now were going back in history to the era of PTM in all honesty not a lot that can be done
tony
