goaty
posted on 25/5/09 at 08:11 PM |
Ebay aeroscreen
does anyone have one of these and could measure it at its widest point please? (where it wraps down the side of the scuttle).
Want to see if it will fit mine as the carbon mods one is too narrow.
thanks in advance
eccsmk
posted on 25/5/09 at 09:01 PM |
ive got one on my indy and one on a tiger avon
if no-one puts the measurements up i will measure them tomorrow for you.
HTH
craig1410
posted on 25/5/09 at 09:10 PM |
I can tell you that it isn't wide enough for a +4" McSorley Locost like mine... My scuttle is from GTS Tuning with a 4" extension to
the width right down the middle. I could probably make it fit as it is quite flexible but the aeroscreen wouldn't be lined up with the
driver's and passenger's seats. I'll probably end up widening it with an aluminium strip.
To be fair, the seller told me he didn't think it would be wide enough but I told him I would either sell it on or modify it. I haven't
decided which yet.
Craig.
Charlie_Zetec
posted on 25/5/09 at 10:10 PM |
As per Craig, I'm building a GTS W7DE (+4) and it didn't fit. He told me it would, but took it back. Personally, from all the luck
I've had trying to find one, I'll either end up with a small perspex windscreen-style unit, or nothing at all, and wear my bike helmet!
craig1410
posted on 25/5/09 at 10:17 PM |
I've already got a pair of Box BX2 helmets which I bought from minihaha.co.uk.
Linky.
The helmets are great and at £29.99 each were a bargain but I want to be able to go out for short trips around town with just my sunglasses on and
perhaps a woolly bunnet. That's what I'm hoping the aeroscreen will allow me to do with a bit more comfort. I'll get it to fit
somehow...
Craig.
austin man
posted on 25/5/09 at 10:32 PM |
Go to b+q and buy some perspex and make ur own its not hard I have just made one for an MK and also made one for a locost 4" wider than
standard. Tools needed tape measure, markerker pen, jigsaw and a hot air gun, tip is to keep the blade cool when cutting (air line or cut small
amounts at a time) use the hot air gun to help you ben the perspex as long as you use gentle heat you wont burn the perspec. I could honestly say the
item produced is as good as if not better than items available off the shelf.
goaty
posted on 26/5/09 at 08:21 PM |
what is the width of your scuttle if you dont mind measuring up???
thanks
goaty
posted on 29/5/09 at 07:47 PM |
any chance of someone being able to measure theres quickly??
cheers
