mr T
posted on 3/6/09 at 08:26 PM |
Help with limited slip diff
Need help with xr4x4 diff please . Just bought a 3.6 lsd and the drive shafts are bolted to a shaft that goes into the diff . I've just compared
it to the standard diff and my shafts have no bolts they have a type of cv joint then the shaft goes into the diff ,will my shafts work with this new
diff thanks
ReMan
posted on 3/6/09 at 08:28 PM |
No
You have push in, these are bolt on
RichardK
posted on 3/6/09 at 08:30 PM |
Can be done but I don't thinks it a straight forward conversion, think David AKA Flak Monkey is doing this as we speak. Maybe worth a u2u or
searching his username.
Rich
Gallery updated 11/01/2011
mr T
posted on 3/6/09 at 08:43 PM |
Thanks Rich it looked like the old ones would pull straight out and mine would go straight back, westfield want £200 a shaft cheers Tony
flak monkey
posted on 3/6/09 at 08:48 PM |
If your push in shafts are ~28mm dia where they fit in the diff then you can sort it easily.
Cut the casing of the push in joint apart and it will spring apart with some persuasion. Remove the circlip from the end of the shaft and pull off the
old joint.
Remove the outer circlip from the diff end of the bolt on shaft and slide off the joint.
Press bolt in joint onto end of push on shaft and fit circlip.
Job done
PS remember to change the CV boot while you are at it
Sera
http://www.motosera.com
mr T
posted on 3/6/09 at 08:56 PM |
Cheers Flak
I dont understand this(Cut the casing of the push in joint apart and it will spring apart with some persuasion) cheers
flak monkey
posted on 3/6/09 at 08:58 PM |
The push in joint is swaged together and you cant remove it without cutting it apart.
The metal can part (the largest dia part) is the bit you need to cut apart. Cut it length ways and peel it off. It might spring apart anyway once its
cut.
Sera
mr T
posted on 3/6/09 at 09:05 PM |
Cheers once i have cut It of can i get new ones to go back on sorry for being thick don't no much about diffs
matt_claydon
posted on 3/6/09 at 09:41 PM |
You don't need to replace it. The whole point is that you are changing the push-in joint on the inner end of the shaft for a bolt-on one so that
you can connect it to your LSD.
Note what Flak said, this only works if your PUSH-IN shafts are approx 27-28mm dia, not the thinner ones which are approx 24mm.
However, I think from your first post that you don't actually have a pair of bolt-on shafts yet? Flak's info is about how to get an LSD to
work with drum brakes. Your other option is to replace your rear end with disc brakes/hubs, then you can just use a pair of bolt-on shafts without any
mods.
mr T
posted on 3/6/09 at 09:55 PM |
Hi Matt
the car is a irs with rear disc and the shafts are made by westfield they look the same on both ends they have these cv joints that need to be cut of
to take apart ,can i not take the shaft out of the lsd and push mine in if they are the same dia cheers
flak monkey
posted on 4/6/09 at 06:01 AM |
Ah, I thought you were trying to use rear drums.
If you have rear discs, then you need bolt on both ends.
As long as they are std sierra length, then you can just get a set of bolt ons for about £20.
You cannot use push in shafts with a bolt on diff and discs.
Sera
mcerd1
posted on 4/6/09 at 08:10 AM |
westfield use both sierra and freelander diff's
I though that most westfields with sierra diff's used the 'bolt-on' CV joints at both ends - but I could easily be wrong
so before this all gets too confusing - mr T could you go and take some photo's of whats on your car at the moment
that way we'll all be able to give you better advice
btw - the CV's on 'bolt-on' shafts (aka: Lobro's) go together like this:
if you can do as flak monkey suggests and make your own hybrid shaft, you'll need a pair of bolt on CV's + gators
westfield sell them for £54 each
but a good motorfactor will get them for half that or less (but may need exchange ones)
these are the best pics I can find at the moment.....
this lot + the CV's & gators is all the bits for shafts with 'bolt-on' ends
and they look like this once they are assembled ('bolt-on' both ends and after 101k on a granada)
I've still got the shafts going spare and 2 of the CV's in this pic and I found a set of push-in shafts the other day
[Edited on 4/6/09 by mcerd1]
