Author: Subject: Mounting Light on Curve
mad4x4
posted on 8/6/09 at 07:03 AM Reply With Quote
I have abit of body on my car that Curves
I need to make a "Wedge" to go between the CURVE and the Light Unit that I which has to be mount on this curve. (using a landrover style lamp)
"Curve is to big just to screw lamp onto"
So how do I do it.
(note due to type of vehilce there isn;t a flat surface big enough that these lights can be mounted on so that in not an option"
So far I thought about P38 filler but don't fancy trying to get both sides to match...
as there is 4 Lights to do (2 Indicator 2 Stop Tail)
Vehicle Rear of Suzuki SJ 413 (4x4)
[Edited on 8/606/09 by mad4x4]
Scot's do it better in Kilts.
dewbries
posted on 8/6/09 at 07:22 AM Reply With Quote
I know it is a long job ut you could make a buck and take a mould off it them make them out of fibreglass that way they would all be the same. Have a look here they used to have loads of help on the site, if you get a catalogue there are some good 'how to's' in it.
http://www.cfsnet.co.uk
Second build. Now refining and changing drive train
Guinness
posted on 8/6/09 at 07:27 AM Reply With Quote
Could you use some waste pipe / drain pipe and cut one end square to the light and one end at the right angle?
Mike
rsmith95uk
posted on 8/6/09 at 08:36 AM Reply With Quote
Hi, a pair of fibreglass 'wedges' were supplied with my CAT kit to enable the rear lights to mount vertically - may be worth a call to Tiger.
Ray
blakep82
posted on 8/6/09 at 01:22 PM Reply With Quote
what lights are they?
________________________
mad4x4
posted on 8/6/09 at 09:56 PM Reply With Quote
Standard Rear Landrover Lights not the NAS spec ones
