LBMEFM
posted on 11/6/09 at 06:02 AM |
Exhaust Can Fitting
I have fitted a larger exhaust can with cat to my MK to reduce the noise level it failed SVA on previously. This has worked but due to the positioning
of this silencer the tail pipe now protrudes out the side of the car about 20-30mm out from the rear wheel. Will this be acceptable for the re-test.
Cheers, Barry
rgrs
posted on 11/6/09 at 07:00 AM |
Don't know but i have my re-test tomorrow afternoon so will ask them if they think it's an issue.
Regards Roger
twybrow
posted on 11/6/09 at 08:32 AM |
Shouldn't be, but be aware that this then becomes the widest point, so your light positions might need tweaking....
Guinness
posted on 11/6/09 at 09:08 AM |
Can you rotate the can, so the outlet either points up in the air, or down at the ground?
Ask him to test the noise first though, as I'm sure someone on here noticed a significant increase in noise when the outlet was pointed at the
road surface, something about the sound waves bouncing back and being amplified / multiplied?
Mike
