givemethebighammer
posted on 8/3/04 at 09:05 PM |
Cheap material for sound deadening
Any ideas of what (cheap) to glue to the insides of the aluminium body panels to deaden any vibration and drumming noise ?
I had thought maybe old carpet ?, also thought of expanding foam filler but seems far too permanent and potentially very messy !!
[Edited on 8/3/04 by givemethebighammer]
Mark Allanson
posted on 8/3/04 at 09:09 PM |
You cannot beat using the proper stuff, sound deadening pads from any bodyshop supply company. Normally used to silence doorskins, they are about
£2.50 each (or less) and are about 12" x 18". You peel off the protective plastic sheet, warm the adhesive side with a heat gun until it
just starts to blister and wack it on.
givemethebighammer
posted on 8/3/04 at 09:13 PM |
so you would use one of these pads in the centre of an average sized door skin or several ?
Mark Allanson
posted on 8/3/04 at 09:53 PM |
Just one, or a part of one - it takes out the resonance. I am going to use them on my ally, just to make sure I don't get that vibration rasp at
certain RPM's (also stops the rivets vibrating loose)
Alan_Thomas
posted on 8/3/04 at 10:18 PM |
Sound deadening? - who needs it! Since running the car it may have the odd rattle but I have never heard them over the noise of the intake and
exhaust. Oh and the wind going past your ears.
My experience of sound deadening materials in various cars I have restored is that it acts as moisture traps.
posted on 8/3/04 at 11:35 PM |
The black bitumen type won't hold moisture, only the foam ones. You can stick them on with spray adhesive or the ones Mark uses, self
adhesive.
yours, Pete.
