goaty
posted on 21/6/09 at 08:29 PM |
pro race 1.2 wheels
Anyone in or around Surrey able to help please??
I need to find someone running the Team Dynamics pro race 1.2 alloys in a 13.
Am looking to buy some but want to check clearance of my Wilwood calipers etc.
I currently have to use 8mm spacing to clear it but i want to get some wheels that wont need them as it has effect the steering geometry in a way i
dont like.
please, if you are able to let me know.
many thanks in advance
goaty
greggors84
posted on 21/6/09 at 08:42 PM |
Im sure MAC1 use the Pro Race 1.2 in 13" with willwoods.
Give them a call and they will be able to help you.
Chris
The Magnificent 7!
Kriss
posted on 21/6/09 at 08:58 PM |
depending on car and rear brake set up, you may want to check the rear callipers clear also
StevieB
posted on 21/6/09 at 09:20 PM |
I'm running front wilwoods and sierra rears - the sierra rear disc set up is a larger diameter than the fronts and I have the same queris
regarding running 13" wheels.
I was at a trackday yesterday (very soggy it was too!) and there was a Mac#1 there running the 13" Pro Race wheels with sierra rear disc setup -
didn't ask if any mods were needed though.
I think Compomotive CXR's are an option too.
bigrich
posted on 21/6/09 at 11:26 PM |
i run them on mine with wilwoods front and rear. sierra rear calipers also fit but need a small tweak to the handbrake return spring.
Give Mark at mac#1 a call.
goaty
posted on 22/6/09 at 06:14 PM |
thanks for the replys,
I am running Midilites 240mm on the front so may be wider if you are using powerlites.
As for the rear i am using sierra calipers with 220mm discs.
Dont think rear should be an issue as its fine with current wheels, it was sticking the wilwoods on that threw things out a little.
Anyone know what uprights MNR's run??
I have cortina ones so need to work out offset for these.
cheers again
