billy
posted on 11/3/04 at 06:10 PM |
steering wheel and boss?
hi peeps,can anyone sugest a good place to buy a small seering wheel and a colapsable boss which is ok for the sva, i had a shock looking thro the
demon tw**ks catalogue.......anyone??????? ta
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
madforfishing
posted on 11/3/04 at 06:21 PM |
This guy, Jim, was loads of help...
No Connection.
www.stores.ebay.co.uk/id=113300174&ssPageName=L2
200mph
posted on 11/3/04 at 06:37 PM |
rally design?
www.raldes.co.uk i think
bought one or two things from them
Mark
posted on 11/3/04 at 07:50 PM |
What kind of column are you using? The boss doesn't need to collapse if the column is collapsible. Halfords do a Sierra centre for £25ish. You
can pick wheels up to fit the boss in local ad-mags or shows. I got mine at the scrappie for £5 (mountney).
yours, Pete.
DavidM
posted on 11/3/04 at 10:42 PM |
Use donor wheel for SVA, then change it afterwards.
Midland Wheel Supplies do reasonably priced steering wheels.
ned
posted on 12/3/04 at 09:37 AM |
i got a moutney boss for a sierra column for £20 off mac1motorsport
Ned.
beware, I've got yellow skin
locoboy
posted on 16/3/04 at 12:08 PM |
Ned,
was that a collapsable one or not?
I am having dramas with the un identifiable non colapsing column on my F27, could this be over come by adding a collapsable boss? would be cheaper in
the long run as the car is all wired up to the existing unidentifiable column switches.
Locoboy
ned
posted on 16/3/04 at 12:34 PM |
Col,
Not sure if the boss is collapsible or not (how do you tell!) i've got a collapsible sierra column, so not ever bothered finding out!
Ned.
posted on 16/3/04 at 12:44 PM |
As DavidM says, there are major advantages in using the donor's wheel for the SVA.
1. It matches the steering column and thus forms a 'complete protection system' (I think that's the phrase they use). In other
words, a Sierra wheel on a Sierra column makes an acceptable system. If you use another wheel you may have to prove that it's up to the
standard.
2. It covers more of your dashboard, so you have a bigger untested area (which goes out to 50mm or so from the rim of the wheel).
I have a nice wide Sierra wheel off a car without power steering - I can just about get my legs under it when I get in - which will be on the car for
the time it takes to pass the SVA. Straight after that it goes in the bin and my nice little Astrali wheel goes straight on!
rgds,
[Edited on 16/3/04 by David Jenkins]
Northy
posted on 16/3/04 at 12:59 PM |
But isn't it a bugger to position the instruments do you can see them with both size wheels?
Graham
posted on 16/3/04 at 01:08 PM |
It would probably be easy enough to weld a bracket for your existing switches to the sierra column outer and replace the one you have so you can use
whatever wheel you want. Lolocost do a Sierra boss for £15 I've noticed and a mountney wheel to fit it for £30.
