Danozeman
posted on 18/8/09 at 11:47 AM |
Windscreen rubber
What rubber do i need to go between the bottom screen to the scuttle?
Dan
Mr Whippy
posted on 18/8/09 at 11:53 AM |
the top one is quite good for this
linky
whitestu
posted on 18/8/09 at 11:58 AM |
Does the screen have a channel at the bottom? If so you need T trim for it - this is on the woolies site:
Description:
T' Section. Usually to seal between bottom of screen and scuttle. Overall length 35mm (1 7/16". Head of 'T' is 8mm
(5/16".
philhoward
posted on 18/8/09 at 12:26 PM |
Also try Seals + Direct Ltd
Bluemoon
posted on 18/8/09 at 12:43 PM |
Measure the T slot in the screen first (if you have one)... The stuff I got was an utter pain to get in to the slot could have done with a smaller
one, it took all day with two of use pulling the sod though (even with washing up liquid)!
Dan
[Edited on 18/8/09 by Bluemoon]
Mr Whippy
posted on 18/8/09 at 01:01 PM |
god there's tonnes on that site! cheers
Danozeman
posted on 18/8/09 at 04:31 PM |
Theres no channel on the bottom. The one whippy says is perfect. Cheers lads.
Dan
Danozeman
posted on 18/8/09 at 04:33 PM |
Actuall no whippys is to small, that goes onto 6mm, The channel is about 15. But thats the style i want.
Dan
