mr T
posted on 22/8/09 at 07:30 PM |
silicone hose
The rubber seal on my bike crabs has split , has anyone used silicone hose to fasten them on and will normal hose do or dose it have to be for fuel
also where can I get 48 mm internal diameter hose any help thanks
jacko
posted on 22/8/09 at 07:36 PM |
thats what i have on my carbs been on about 3 years i had to super glue them to the carbs though
big_wasa
posted on 22/8/09 at 07:41 PM |
yep you can get 48mm or look for 1 7/8"
If you get hose joiners you can cut them in half.
irvined
posted on 22/8/09 at 07:45 PM |
Try SFS Performance for your silicon hose, cheaper than Samco and I've had nothing but excellent service from them and good turnaround time for
special orders.
http://www.sfsperformance.co.uk/
http://irvined.blogspot.com
mr T
posted on 22/8/09 at 08:07 PM |
Hi Jacko was the problem letting air in or was the pipe coming off, I have a set of Blackbird carbs and there's about 10 or 12 mm to fasten to
is that enough with a jubilee clip
[Edited on 22/8/09 by mr T]
jacko
posted on 22/8/09 at 08:21 PM |
They use to come off so i glued them on + jubilee clips then made a bracket to support the carbs
blakep82
posted on 22/8/09 at 11:01 PM |
people say they degrade with petrol, but as said above people have used them for years without trouble
________________________
mr T
posted on 23/8/09 at 06:36 AM |
Thanks for the replies. Super glue and silicone hose now on order![](/images//smilies/smile.gif)
