tashlotty
posted on 23/8/09 at 07:31 PM |
CVH Cooling
Hi folks,
jst want to pick the brains of anyone using a 1.8CVH.
I intend to get rid of the original carb and bumf that surrounds it and use bike carbs. As the thermostat housing is part of this, what have others
done.
It's been suggested I use one of the core plugs at the back of the engine (has bolt around outside). Is there a stock housing that will fit or
will I have to make an adaptor?
Any ideas greatly appreciated.
Daz
avagolen
posted on 23/8/09 at 09:19 PM |
Hi, I also plan to use the 1.8cvh and a thermostat housing from a 1.6cvh that mounts on the back of the cylender head. WrigglyPig use a 'double
piped' housing that used both core plugs, but the 1.6cvh only uses one of them.
I have yet to find out if the smaller hole in the thermostat housing requires a drilling in the head.
I will use a blanking plate between the inlet manifold and the head that will cover the old water hole. - Has anyone got any pics of the rear of a
1.6cvh head that will help the build?
Len
Surrey Dave
posted on 23/8/09 at 09:43 PM |
FWD thermo Housing
Use a FWD CVH Housing , then plate over the inlet water way with the manifold plate
![](/galpreviews/a1004704-EngineBayManifold Good sml.jpg) ![Rescued attachment EngineBayManifold Good sml.jpg](/gallery/a1004704-EngineBayManifold Good sml.jpg) Rescued attachment EngineBayManifold Good sml.jpg
avagolen
posted on 24/8/09 at 12:18 AM |
Hi Dave. that looks like my thermostat housing.
Does the head have an extra small hole at the upper edge like the housing does?
Any pic's will be helpfull. Has anyone got any?
Just dropped into an engine shop this PM and they had a 1.6CVH head in. He gave me a quick gander and there it was, a small hole in the head that
lines up with the hole in the thermostat housing.
So, if you intend to use a FWD thermostat housing on the end of the head, knock out the left core plug, viewed from the rear, and drill a hole. Use
the thermostat housing gasket to mark before drilling.
Len.
Len.
[Edited on 24/8/09 by avagolen]
[Edited on 25/8/09 by avagolen]
