55ant
posted on 2/9/09 at 04:51 PM |
roll bar
hello all, sorry to keep posting away asking simple questions., i have the most basic roll bar
pic makes it look like just two uprights! but its a basic bar. now i have heard that really you should have back stays on the bar?
so i am after one of THESE, but despite searching on this site and google i cant
find anywhere that sells'em?
could someone kindly point me in the right direction and give me an idea of price im going to be looking at? also could i just taking it to a
engineering company and have them weld in some stays, im not too fussed about rose joints, aslong as it wont snap if the worst happens?
Danozeman
posted on 2/9/09 at 05:51 PM |
That looks MK ish?
Id just weld some back stays onto yours. Muchos easier. Is your welded to the chassis or bolt on?
Dan
55ant
posted on 2/9/09 at 05:53 PM |
hi, cheers for the response, its bolted on by four bolts on mounting plates, may just go down the back stay welding route
pewe
posted on 2/9/09 at 05:58 PM |
Russbost on here was offering to have one-offs, modifying tubing made by his supplier.
Maybe worth dropping him a U2U.
Cheers, Pewe
robocog
posted on 2/9/09 at 06:20 PM |
You got something solid to attach the rear stays to at the back of the car?
My MK has no metal round the back there..
(just fiberglass) unlike uncle Rons plans and 90% of other chassis clones
Unless your after the kind of roll bar that goes to the bottom chassis rails in the corners each side of the tank?
Regards
Rob
Steve Hignett
posted on 2/9/09 at 06:39 PM |
Are you sure that you want, just rear facing tubes???
rgrs
posted on 2/9/09 at 07:30 PM |
Try speaking to grant from obp, he supplied me with my back stays at a good price delivered.
Roger
55ant
posted on 2/9/09 at 07:31 PM |
hmm, yep i think i will stick with just the rear stays, i thought most rear stays went down to the low bar on the mk? if not then im sure it has been
done/i could get it done?
cheers all, going to try and hunt down a firm that can do it, any specifications for the tubing? 2.5 steel?
James
posted on 2/9/09 at 10:12 PM |
Your car's an MK right? Have you tried contacting them to ask them about it?
James
- Muhammad Ali
