scudderfish
posted on 9/9/09 at 07:39 AM |
Removing Mini wiper arms
I'm incompetent. I need to get my wiper arms off. I couldn't see any obvious means of holding them on, so are they just push fit? I
didn't want to pull too hard last night in case they weren't.
Regards,
Dave
owelly
posted on 9/9/09 at 07:48 AM |
You need to tilt them on the shaft. Bend the wiper arms on their pivots, then push the pivot towards the windscreen. The base of the arm should wobble
on the shaft and then it should slide off. If that makes any sense??
http://www.ppcmag.co.uk
Jimbob
posted on 9/9/09 at 07:49 AM |
Yes there just pushed onto the spline but they can be tight so you may need to lever with a rag covered screwdriver
posted on 9/9/09 at 10:46 AM |
Leverage and buttock clenching whilst listening out for sounds of gel-coat cracking....
ken555
posted on 9/9/09 at 07:31 PM |
Normally I find, 60 mph in the rain, gets them detached from the car.
scudderfish
posted on 9/9/09 at 07:38 PM |
They're off. Thanks. Whoever built my car didn't mount the wiper motor to anything, it just flaps around on the end of the tube. The
tube, needless to say is somewhat bent and the wipers wouldn't wipe very well. I'm gently straigtening the tubes and making up a bracket
to bolt the motor to the scuttle.
