Author: Subject: Show me your Bonnet scoops
kj
posted on 9/9/09 at 03:34 PM Reply With Quote
As the title goes, i will need to fit a small one where my air filter used to be, was thinking of filling the hole but don't want it to crack, and then fit the one at the front of the bonnet line like the Mach#1.
Its a ali bonnet.
Think about it, think about it again and then do it.
iiyama
posted on 9/9/09 at 04:22 PM Reply With Quote
And a close up....
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Humbug
posted on 9/9/09 at 04:52 PM Reply With Quote
Why would filling in an ali bonnet crack?
Pics below show:
a) small scoop
b) patch where the old manifold used to go over the side rail
Both not too difficult to do and look fairly neat (IMHO ) Rescued attachment bonnet.JPG
posted on 9/9/09 at 05:16 PM Reply With Quote
r1bob
posted on 9/9/09 at 07:41 PM Reply With Quote
Whats the verdict with these scoops,,obviously catches the cold air and drives it in at speed, my filter stick's out the bonnet about 4" just to get the carb's to work properly. Would i benefit?
kj
posted on 10/9/09 at 06:44 AM Reply With Quote
iiyama, can't see the pics, i know ali won't crack its just if i put a glass fibre scoop over i don't want cracks, if it does not cover the hole from my old K&N it was a pinto so on the lhs.
kj
posted on 10/9/09 at 06:45 AM Reply With Quote
Yep Humbug, yours looks simple and efective, i think i may have some ali left.
MattD
posted on 14/6/11 at 03:01 PM Reply With Quote
Bonnet
Originally posted by iiyama
And a close up....
Sorry... new site member..
I'm looking for a large bonnet bulge to cover my new engine mod.
If you feel like selling me one, please give me a call ...
Funnily enough... its my SSC Stylus next to you at the Goodwood Breakfast Club meet :-)
Rgds
Matt
07990 586214
scutter
posted on 14/6/11 at 03:34 PM Reply With Quote
scoop
scoop
I just need mine to clear the VVC solenoid. £4 off ebay.
ATB Dan.
MattD
posted on 14/6/11 at 03:51 PM Reply With Quote
Bonnet
When I said large, I meant it.
Got to cover an Integrale Turbo lump, which is quite tall.
Have made a bulge as attached, but not happy with it
Want to cut the old bump out & bolt on a carbon one that's a decent shape.
franky
posted on 14/6/11 at 04:13 PM Reply With Quote
2cv
posted on 14/6/11 at 04:44 PM Reply With Quote
Hello MattD, some time ago I posted a series of threads covering among other things the making of bonnet bulges and scoops in aluminium using just hand tools. It is easy to do and you can make the exact shape you need for the job. The thread can be found in the Tools and Techniques section. here is the link:
http://www.locostbuilders.co.uk/forum/37/viewthread.php?tid=145585
I'll be happy to answer any queries you may have. Please feel free to drop me a U2U.
[Edited on 14/6/11 by 2cv]
MattD
posted on 14/6/11 at 07:31 PM Reply With Quote
Cheers for the reply - will take a look.
It's the surface finish in Ali that I'd be worried about !
MattD
posted on 14/6/11 at 07:34 PM Reply With Quote
Originally posted by franky
Hi Franky
Is that the carbon mods one ?? Don't think it's big enough for what I need.
In particular it's height I'm looking for.
Matt
franky
posted on 14/6/11 at 08:40 PM Reply With Quote
No this is a black GRP one, same size as the carbon mods one. GKD sell them
I've a carbon mods one i'm going to sell when I get round to it though....
It gives me about 2 inch to clear the linkage on my throttle bodies.
2cv
posted on 14/6/11 at 09:16 PM Reply With Quote
code:
Cheers for the reply - will take a look. It's the surface finish in Ali that I'd be worried about !
With a bit of time and a bit of care not only can all the forming marks be removed but you can end up with a very nice polished finish.
Bonnet bulge trial fit
sky12042
posted on 14/6/11 at 09:20 PM Reply With Quote
Just a quick question.
Whats the best way of fixing to bonnet, mine is grp scoop and bonnet, silkaflex, bolt, or bond it on?
Dont want it ripping off at speed.
[Edited on 14/6/11 by sky12042]
2cv
posted on 15/6/11 at 05:51 AM Reply With Quote
If I were fitting an aluminium one to a fibreglass bonnet, I'd make it with a flange, insert it from the underside of the bonnet and bond it with panel adhesive. I wouldn't use countersunk rivets because even filled you will see where they are.
ashg
posted on 15/6/11 at 08:35 AM Reply With Quote
picts of the engine please is it a twin cam or 8valve? 1600 or 2000
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
John Bonnett
posted on 15/6/11 at 09:54 AM Reply With Quote
Some years ago I built a Sylva Phoenix into which I fitted a Cosworth YB engine. A large bonnet bulge was needed to accommodate the height of the engine and I made this in aluminium. I hope pictures follow. John
Hammerform
Hammerform
Forming
Forming
Fitted
Fitted
Finished
Finished
[Edited on 15/6/11 by John Bonnett]
MattD
posted on 15/6/11 at 04:03 PM Reply With Quote
Old Pic... has moved on a bit since then...
Its a twin cam 16V 2Ltr from a Thema, soon to be on Emerald electronics.
Was previously fitted to a Fisher Fury, & needed the pedal box narrowing to fit into my Stylus.
iiyama
posted on 16/6/11 at 04:13 PM Reply With Quote
Matt, you have U2U mate.
MattD
posted on 16/6/11 at 07:09 PM Reply With Quote
Franky
Just seen your build thread & the engine you've got under the hood.
Like it
[Edited on 16/6/11 by MattD]
MattD
posted on 16/6/11 at 07:11 PM Reply With Quote
Hammerform
Hammerform
Forming
Forming
Fitted
Fitted
Finished
Finished
Cheers John, remember your Pheonix when it went up for sale.
