Author: Subject: Advice...
Dave Bailey
posted on 10/9/09 at 04:34 PM Reply With Quote
Advice...
All,
I have to sand the edge of the bonnet to get the shut line correct and the problem is that I am concerned that the gel coat will chip away when I cut / sand the edge.... Any tips?
thanks
Dave B
posted on 10/9/09 at 05:03 PM Reply With Quote
Make sure if you're cutting or sanding then you only do so away from the gelcoat so if it cracks it cracks on the inside rather than the gelcoat. Otherwise go slowly. I used a dremel type sanding drum when I fettled my bonnet. Worked very nicely.
MikeR
posted on 10/9/09 at 05:11 PM Reply With Quote
I've used a dremil with a cutting disk and sanding drum to make hte opening in my nose cone / sand the rear arch cut outs (stuart taylor arches).
Very impressed - just be careful with the dust, its not good for you. My biggest problem is making sure i didn't go too far, didn't have any other issues.
