speedyxjs
posted on 12/9/09 at 07:34 PM |
Bonnet - Change of plan - Paint
Ok, due to the lack of room in the garage (despite a new garage door), my original plan to make a fibreglass front end is out the window and i have
decided to make a metal frame from 10X10x1mm strips of steel and 1mm steel sheet over the top.
Has anyone built a bonnet like this and maybe has some advice?
Also, has anyone painted their car when it is built up rather than each panel individually?
big_wasa
posted on 12/9/09 at 08:04 PM |
Paint it as the last job, its a locost not a kit so thing will be fitted on and of all the time and things get marked.
posted on 12/9/09 at 09:01 PM |
1 mm steel? most peeps use 1.5 mm to 2 mm aluminium - that is gonna wiegh a fair but; assuming you are building a 7 type car.
speedyxjs
posted on 13/9/09 at 07:25 AM |
I may still use ali but i need to plan it a bit better to make sure i can get the bends right.
Its a sevenish chassis and the back end will silghtly resemble a seven but the front is a whole new design.
