tashlotty
posted on 15/9/09 at 05:51 PM |
1.8cvh tensioner
Hi all,
having just removed the water pump and tensioner, I noticed there was no tensioner spring!!
Should it have one?? Or is it adjusted to get the tension correct then tightened up??
Cheers Daz
cheers
Daz
big_wasa
posted on 15/9/09 at 06:03 PM |
Yes a spring about 50mm long that sits on the back ot the tensioner.
But I would think you could get by without it.
jollygreengiant
posted on 15/9/09 at 06:13 PM |
The spring is NOT necessary, but you must be able to tension the belt correctly. One quarter twist on the longest free run length using only light
pressure with your thumb and index finger.
tashlotty
posted on 15/9/09 at 06:21 PM |
Cheers Fellas
Glad to hear that, as it did run without before.
Just worried it was botched before selling on.
cheers
Daz
dhutch
posted on 15/9/09 at 08:38 PM |
Mine doesnt have one.
- Presumably then said magic spring sets the tension right? Or is ment to?
Daniel
