LBMEFM
posted on 21/9/09 at 06:45 PM |
Roll Bar
Sorry this is the second post on this subject. I want to beef-up my roll bar. I am thinking of puting a detachable bar from the top down to the
passenger foot well, and a diagonal across the the back but where do I put the rear bracing as behind the MK is just a small tube that holds the fuel
tank and nothing else but I have seen many MK's with rear struts including Hellfires so where do you attach at the bottom end. Pics please if
poss. Ta Barry
[Edited on 21/9/09 by LBMEFM]
sebastiaan
posted on 21/9/09 at 07:15 PM |
Mine go to the bottom of the chassis, and end up on welded in plates besides the petrol tank. No clear pics unfortunately, but i think you can get the
point from this:
rear almost complete
It does make fabricating a decent boot cover a bit tricky though....
O, and sorry for the oversized pic.
Guinness
posted on 21/9/09 at 07:16 PM |
The removable bar running forward into the passenger footwell is a petty bar if it helps with your search.
The back stays normally go down to a plate welded in between the round tubes at the bottom of the chassis and the sloping back stays.
HTH
Mike
mookaloid
posted on 21/9/09 at 07:17 PM |
You probably need the mounting plates which I don't think are fitted as standard.
Don't have a specific picture but you can see half of the plate in the bottom right hand corner here
HTH
Mark
Steve Hignett
posted on 21/9/09 at 08:01 PM |
On a MAC1 they use a couple of wishbone bushes at the rear, so you could easily do that yourself, even bolt them on if you wanted.
I don't have a pic of them with the roll bar going to them but here they are anyway!
Guinness
posted on 21/9/09 at 08:11 PM |
Wishbone bushes is genius!
Mike
ReMan
posted on 21/9/09 at 08:13 PM |
Se this pic in my archive
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=1111.jpg
ReMan
posted on 21/9/09 at 08:14 PM |
Thanks Steve
[Edited on 21/9/09 by ReMan]
Steve Hignett
posted on 21/9/09 at 08:25 PM |
reman
Bladepump
bigrich
posted on 21/9/09 at 09:31 PM |
rollbar fitted to brackets
blakep82
posted on 22/9/09 at 01:07 AM |
Mike
is it though? i think the brackets would just shear off
________________________
LBMEFM
posted on 22/9/09 at 06:07 AM |
Thanks guys, Barry (LBMEFM)
MikeR
posted on 22/9/09 at 06:58 AM |
I think the wishbone bushes idea is no longer FIA / MSA compliant. Therefore if you want to race you need to check up on this.
