LBMEFM
| posted on 24/9/09 at 07:32 PM |
Full cage
Are full cages easy to fit, I have an MK Indy, and any ideas of the cost or would they be easy enough to make from scratch. Barry
A1
| posted on 24/9/09 at 07:38 PM |
i recon youre best off getting the mk one from scratch... shouldnt be too hard to fit one aftermarket though...
| posted on 24/9/09 at 07:58 PM |
What have you got fitted at the moment?
Chances are you'll need plates welding into the chassis to either weld or bolt the roll cage to. Plates to the rear of the chassis either side
of the fuel tank and plates in the seat area either side of the car.
LBMEFM
| posted on 24/9/09 at 08:02 PM |
Currently got the standard MK bolt-on fitted. A full cage from MK is approx £500, is that reasonable.
Ben_Copeland
| posted on 24/9/09 at 08:03 PM |
Barry, "welderman" made mine. I haven't fitted it yet, but you can pop over and try it out if you want.
Should fit a MK fine.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
LBMEFM
| posted on 24/9/09 at 08:05 PM |
Sounds good Ben, hopefully I will be free next Tuesday, are you still on holiday then?
Ben_Copeland
| posted on 24/9/09 at 08:06 PM |
Yes mate, i'm off all week.
Ben
Roadster
mark chandler
| posted on 24/9/09 at 09:41 PM |
I paid £70 for a 6m length of 2" CDS 5 years ago and paid £15 per bend for the rear hoop, could not bend without kinking myself.
So doing it yourself ~£200 but its quite hard keeping everything square. I have made a few cages before, just a few millimeters out shows when you
view from different angles, its not that easy to make a good one.
Nash
| posted on 24/9/09 at 09:52 PM |
You're not on holiday again are you!?!??!
Did you see the post about Lydden Hill on Saturday? Not going to take the Indy but might be interested in sticking my nose down there to have a look.
for an hour or so. You interested?
........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
welderman
| posted on 24/9/09 at 10:52 PM |
busy at work at the mo (real work not kit related) but, ive two cages on order and two half cages to do, just trying to find time to make
them.
Thank's, Joe
I don't stalk people
Ben_Copeland
| posted on 25/9/09 at 06:34 AM |
........Neil
Yes i am STILL on holiday.
U2U away
Ben
Roadster
A1
| posted on 25/9/09 at 10:03 AM |
one thing i noticed on the mk cage was the diagonal behind the seats got in the way of the harness bolts...had to trim one a bit to get it in
procomp
| posted on 30/9/09 at 07:37 AM |
Hi
Not sure if the OP is thinking of using the car for track days but saw mention of lydden trackdays above. Be Warned that more and more track day
operators are asking for MSA compliant roll cages. That means that all the ones with double bends in the front legs are non compliant. And also the
ones with the high angle bends in the roof bars are not either.
Cheers Matt
