speedyxjs
| posted on 8/10/09 at 11:51 AM |
Fixing ali to steel without rivets
Planning my bodywork and i am thinking about fixing ali sheets to a steel frame but dont want loads of rivets on show.
Is there any way to do this?
blakep82
| posted on 8/10/09 at 11:56 AM |
sikaflex i guess. i'd prefer rivets though (or both)
________________________
balidey
Velcro...
http://www.locostbuilders.co.uk/viewthread.php?tid=121130
Or seriously, a high stength adhesive would do the job. Sikaflex have more than one product in their range, some of which will easily outperform
rivets.
rj
| posted on 8/10/09 at 12:07 PM |
I have not used any fixings on the sides of mine, just used screws along the top and bottom i.e. where top/ bottom bend over the chassis tubes. It
works fine, and added advantage is that I can take the panels off without damage
speedyxjs
| posted on 8/10/09 at 12:08 PM |
This isnt for the side panels btw. Its for a new style full size nose.
Miks15
| posted on 8/10/09 at 12:25 PM |
New style hey? whats it gunna look like? any pics?
speedyxjs
| posted on 8/10/09 at 12:27 PM |
Trying to draw a rough sketch now but im no artist and it aint easy
It will probably incorporate MG/Mini style headlights but all the sketches i have done so far all look like a streched midget
omega0684
| posted on 8/10/09 at 12:47 PM |
for a nose cone i would recommend 2 rivnuts on either side
speedyxjs
| posted on 8/10/09 at 12:59 PM |
This is a very rough drawing but it shows the idea.
The black line shows where the bonnet and the nose meet.
blakep82
| posted on 8/10/09 at 01:00 PM |
will it look like a normal size person then?
i got chatted up by a big midget once. she had the proprtions of a midget, but was normal size.
myke pocock
| posted on 8/10/09 at 08:22 PM |
Permanantly fixing alluminium to steel. Clean the area absolutely perfectly and use VHB (Very High Bond) tape. Not cheap but if you use it correctly
it will never come off. I had to remove a stainless steel sign about A4 size from a black 5mm acrylic panel and it needed a screwdriver to open up a
gap then a hacksaw blade slipped into the gap to cut the tape out. Still took ages!!!
neilj37
| posted on 10/10/09 at 04:24 AM |
personally i think permanently fixing the panels instead of rivetting could cause problems at a future date if you ever needed to remove the panel for
say access or it was damaged. its a lot easier to drill out rivets than remove adhesive.
