Author: Subject: Headlights...An issue or not!
Dave Bailey
posted on 18/10/09 at 03:43 PM Reply With Quote
Well.. I was worried that I wouldn't get the min 500mm height but the good thing is I have... The bad thing is that I am concerned about how stable the lights are. I have not used a welded rigid bracket but have used some carbon tube mounted to an ally plate on the chassis. If you tap the lights they vibrate so the patern will be shaking I expect... Is this normal for a car of this type with cycle lamps?
Headlight Mount 1
Headlight Mount 1
Headlight Mount 2
Headlight Mount 2
Headlight Mount 3
Headlight Mount 3
thanks...
omega0684
posted on 18/10/09 at 03:58 PM Reply With Quote
when you take the car out for a test run you'll soon find out, another i would do is watch them with the car idling and try and see how bad they vibrate.
posted on 18/10/09 at 06:00 PM Reply With Quote
Never mind Mr IVA - they'll really get on your nerves when you drive at night...
iceman26
posted on 18/10/09 at 06:04 PM Reply With Quote
i failed on sva for that put a screw in to the tube to stop it rotating
that whwt i did to stop movement
omega0684
posted on 18/10/09 at 06:35 PM Reply With Quote
are they real carbon fibre shells?
Dave Bailey
posted on 18/10/09 at 07:59 PM Reply With Quote
Thanks guys.....
Yep they are real carbon but have been strengthened with some glass fibre inside the bowl....
thanks...
Dave B
[Edited on 18/10/09 by Dave Bailey]
Nash
posted on 18/10/09 at 10:49 PM Reply With Quote
I have these on mine
http://www.s-v-c.co.uk/prod/CFE-headlamp.html
......Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
