Fred W B
posted on 22/10/09 at 08:04 AM |
RAL code equivalent for 380 Camouflage Dessert Sand?
Can locostbuilders keep up its reputation?
Can anyone quote a RAL colour code equivalent for a BS381C colour - 380 Camouflage Dessert Sand.
Fred W B
balidey
posted on 22/10/09 at 08:16 AM |
Just had a look in my colour cross-reference directory. There doesn't seem to be a published RAL match. So the best way would be to go to your
local paint-shop and get them to colour match a swatch.
Not really the answer you wanted.
Humbug
posted on 22/10/09 at 08:18 AM |
Fred W B
I prefer sand to be in deserts rather than desserts
[Edited on 22.10.2009 by Humbug]
Fred W B
posted on 22/10/09 at 08:43 AM |
Thanks for quick response. Unfortuantely I don't have a sample
Fred W B
posted on 22/10/09 at 09:06 AM |
Do you not have ggoogle in Southernest Africa?
RALcodes here?
Fred W B
posted on 22/10/09 at 09:15 AM |
Yes we do, and I tried their first. The chart you link to is the BS number codes
I know the BS code
I know what it "looks" like
I need the RAL code
But thanks for the effort
Fred W B
balidey
posted on 22/10/09 at 09:17 AM |
No, and neither does my paint shop, but what we have to do to match say an ICI paint colour mix is make a small amount, spray up a sample, then use a
colour swatch to match it, or use a colour spectrometer. A local paint shop should be able to sort that out.
RALcodes here?
Not sure what that link shows apart from the fact that BS-381C 380 Camouflage Desert Sand is the same as BS-381C 380 Camouflage Desert Sand. it
doesn't say what the RAL code is.
McLannahan
posted on 22/10/09 at 10:15 AM |
http://www.e-paint.co.uk/RAL_Colourchart.asp
This might help?
As he states - guidance only because so many monitors are different, but if gives you an idea!
posted on 22/10/09 at 12:36 PM |
ok, I thought the 3 digit number was the RAL code, oh well ....
Andybarbet
posted on 23/10/09 at 07:48 PM |
Our 1976 mini is british leyland 'Sandglow' its also the colour of the original camel trophy landrovers - not sure if this is the sort of
sand colour you meant but thought i would mention it in case.
I think there are some mini pics in my archive - should give you an idea if its what you are looking for.
Good luck with the search
