Author: Subject: Whato to use to polish cellulose paint
smart51
posted on 22/10/09 at 07:02 PM Reply With Quote
I've painted half of my new car with cellulose which has turned out OK but with more orange peel than gun finish, so I've flatted an area and polished with Farecla G3. The result has a bit of reflection but not exactly a lovely shine. What can I use to get that last bit of extra shineiness?
tomgregory2000
posted on 22/10/09 at 07:19 PM Reply With Quote
try some G10
super fine so does require a bit of effort
edit: i did a door on a mk2 golf with it and ended up with a finish soooooo smooth like glass and a lovely finish but requird a lot of effort, i wish i had a machine
[Edited on 22/10/09 by tomgregory2000]
philw
T cut then wax it.
Must try harder
Mark Allanson
posted on 22/10/09 at 07:47 PM Reply With Quote
Originally posted by philw
T cut then wax it.
NOOOOOOOOOOOOOOOOO!!!!!!!!!!!!
T cut has ammonia which will break down the paint and wax will seal the surface and stop the celly from completely drying - it takes 3 weeks from gun to polishing.
G3 in a machine mop should do the job, it is a combination of the abrasive and the heat generated by the mop which will give the shine.
blakep82
posted on 22/10/09 at 11:58 PM Reply With Quote
i think turning the air pressure on the gun down might reduce the orange peel thing
________________________
RAYLEE29
posted on 23/10/09 at 11:20 AM Reply With Quote
or flat back and spray again but thin the paint more and get the pressure right will only need a light coat as you already have the depth
Ray
