Author: Subject: 1 or 2 washer jets?
Humbug
posted on 24/10/09 at 04:21 PM Reply With Quote
1 or 2 washer jets?
I'm in the process of setting up my screen, wipers and washers. I bought a washer kit which has bag, pump, tubing, etc. and 2 washer jets, each with 2 holes. For a screen as small as a seven's, is it really necessary to use 2 jets or would 1 do? I am sure I have seen sevens with just one. I've got 2 so I can use them, just interested.
Also, with 2, do you put them in line with the wiper spindles, or spaced evenly across the scuttle?
Simon
Bluemoon
posted on 24/10/09 at 04:31 PM Reply With Quote
I have one central that contains two jets, correctly adjusted it's fine.. Don't see to need for for jets in total..
Dan
posted on 24/10/09 at 05:10 PM Reply With Quote
I've also just got one central jet. The coverage isn't the problem It's the ferocity of the spray. I keep on meaning to put an inline resistor to the pump to calm things down a bit....
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 24/10/09 at 07:15 PM Reply With Quote
interesting, i have put both on but agree the ferocity of the water stream is awesome!! Hopefully this pic will help you - shows the coverage too
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 24/10/09 at 07:18 PM Reply With Quote
A few more pics that hopefully will help
Humbug
posted on 24/10/09 at 07:43 PM Reply With Quote
Thanks, chaps. So, if I use just one and mount it half way down the bonnet it might have the right pressure/volume on the screen?
posted on 24/10/09 at 09:18 PM Reply With Quote
Still probably have too much!!
