Author: Subject: How do i fit my side screens
BodyshopSimon
posted on 11/12/09 at 09:30 AM Reply With Quote
Got some new sidescreens from Tiger to go on my Cat e1 but no idea how they fit?
They came with a bag of bits but if anyones got any photos they could put up that would be great.
Cheers simon.
Buy it...Fit it...Remove it...Cut it...Fit it again...Remove it...Hit it with a hammer...Fit it again.
HOL
posted on 11/12/09 at 03:17 PM Reply With Quote
Si,
Have you still got those pics of my Super6 I sent you over on the tiger forum? There are some pics of my screen.
You should have 8 bits that when put together will make 4 hinges, where the top can be lifted off-of the bottom.
The bottom bits are those that have the 'post' potruding and the tops are those that have a cup that fits over the post of the bottom part.
The bottom's bolt into the side of your windscreen frame and orientated in a straight line (in line with the screen - 30degs-ish) and the tops bolt into the front of your doors.
When fitted and closed the door will cover the opening from the top, to the bottom of the frame, but when swung open, the door with swing up at about 30 deg to the vertical.
To remove them, you just lift the doors up and they will come off of the bottom hinge posts.
Im sorry I dont have a pic with me, but you look at the ones I sent you, it might help.
[Edited on 11/12/09 by HOL]
BodyshopSimon
posted on 11/12/09 at 09:00 PM Reply With Quote
Cheers Andy ! As luck would have it i did save the images thanks! They say a picture paints a thousand words and all seems to click into place now.
How did you secure your poppers? screws ?
Cheers Si.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 11/12/09 at 09:10 PM Reply With Quote
Cheers Si.
Hi, could you post these pics up, i would be interested to have a look.
tul214
posted on 11/12/09 at 11:32 PM Reply With Quote
Heres a picture/dims of mine off my S6 if it helps?
Mark
1.6 Raw Super6 sold
