Author: Subject: Foolish Rivet Question
James
posted on 15/4/04 at 12:22 PM Reply With Quote
I'm about to put a Screwfix order in- including the bodywork rivets.
Not having riveted (oh Sir) anything before I'm not sure of the best size to go for.
They are listed in Screwfix as 4.0mm x 10mm etc. (which is the size I was going to go for) but I'm not quite sure what the 4.0 represents.
If you look at the picture below:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=rivet.jpg
Is the 4.0mm figure the diameter of the 'head' of the rivet [A] (ie. the bit you see) or is it the diameter of the shaft [B]?
Also, if it's [B] should the drilled hole in the chassis be the same diameter?
Thanks- any info greatfully recieved.
James
Mk-Ninja
posted on 15/4/04 at 12:27 PM Reply With Quote
James
The 4mm is the diameter of rivet that goes into the hole. I drilled all mine 0.1-0.2mm biger than the rivet size. If you drill it size for size you have to hammer them in with a tube over the pin.
HTH Gordon
I'm sure I've got one, just don't know where I've put it
ned
posted on 15/4/04 at 12:28 PM Reply With Quote
Jim,
If you want to get enough bits for free delivery and haven't already I'll happily go in with you for some rivets for when i get that far!
Ned.
beware, I've got yellow skin
MikeR
posted on 15/4/04 at 12:46 PM Reply With Quote
are they hollow or solid shaft rivets?
(i think you want solid shaft)
James
posted on 15/4/04 at 12:54 PM Reply With Quote
Originally posted by ned
Jim,
Ned.
Sounds good. I was gonna go with these- are they what we/you want? Code: 15725
I currently have £92 worth! Need another £8 to get £6 off if you see what I mean!
I may suddenly have to look into painting the garage floor or something!
James
James
posted on 15/4/04 at 12:56 PM Reply With Quote
Mike,
I was going to go with these: http://www.screwfix.com/app/sfd/sea/searchresults.jsp;jsessionid=VWTQFK2QVRWMFCJO2C4CHPQ?_dyncharset=UTF-8&q=&n=15725&pn=1&pd=1&pi =1&cn=1&cd=1&x=15&y=10
Which I guess may not be solid but I thought they were what people had recommended. I'm probably wrong though!
James
Mix
posted on 15/4/04 at 02:31 PM Reply With Quote
James
The rivets you have indicated will be fine.
As for the size of drill to use, I would use the same size as the rivet, (4mm in this case), drilling oversized holes will make assembly easier but also allow the panels to 'fret'. Pop rivets do not expand into the holes as solid rivets do.
(Before I get shot down in flames, Yes I know it is possible to obtain structural 'break stem' rivets that will expand into the hole but as far as I'm aware Screwfix do not supply them)
Mick
James
posted on 15/4/04 at 02:50 PM Reply With Quote
Perhaps I should have said: I'm not planning to do the floor with these (which presumably needs most strength) as it's welded. It's just the side panels/rear that I'm doing.
Ned, you want in still? Anyone else who I'll see soon at Walton etc.?
James
Mix
posted on 15/4/04 at 03:04 PM Reply With Quote
Those rivets would provide more than enough stength for fitting a floor.
My comment about the size of holes is more valid in the case of side panels, The thickness of the material will probably be less and the rivets may well be visible.
Mick
posted on 15/4/04 at 03:11 PM Reply With Quote
Stainless steel rivets are a good idea for the floor you can get them here http://www.rivetwise.co.uk
They also have good info on drill sizes
James
posted on 15/4/04 at 03:52 PM Reply With Quote
Ok, thanks all.
4.0x10 Screwfix rivets for the side panels it is then!
James
ned
posted on 15/4/04 at 04:03 PM Reply With Quote
James,
Yeah, still want in. need rivets for floor, bulkhead panels and sides..
when you wanting to put theorder in? i cn call you if urgent! off home now though (today)
Ned.
theconrodkid
posted on 15/4/04 at 04:21 PM Reply With Quote
you could allways use the black gunge windscreens are put in with,no holes to drill
who cares who wins
pass the pork pies
Fozzie
posted on 15/4/04 at 07:31 PM Reply With Quote
Quote:
''Anyone else who I'll see soon at Walton etc.?''
Thanks for the thought James!, but Ok for bits,
See ya Sunday
ATB fozzie
James
posted on 15/4/04 at 11:04 PM Reply With Quote
See ya Sunday
ATB fozzie
Yeah, yeah, it's alright for those of you past the Screwfix bits building stage!
James
DaveFJ
posted on 16/4/04 at 08:06 AM Reply With Quote
I would agree (get this you don't hear it very often from me!) that the pop rivets you mention would be adequate for general panelling. (just) BUT keep an eye on them... the are very weak and you may well need to replace some from time to time.
As for drilling....... if they are 4.0mm rivets use a 4.0mm drill do NOT be tempted to drill oversize.
If you are riveting ally to steel then you may be best off with monel metal rivets - you should ideally still use a good jointing compound though....
As for the floor - if any one is considering it I would suggest that these types of rivets are not up to the job and structural breakstem rivets are needed (I used 4.8mm structural at 20mm pitch - staggered - they cost about £40 for 600 from the states but were worth it IMHO)
Sounds like I'm preaching again - but what the hell I'll post it anyway!!
Dave
NS Dev
posted on 16/4/04 at 10:37 PM Reply With Quote
I would agree that normal ally pop-rivets do tend to shear off when vibrated a lot, I have to replace mine quite a bit on my grasstrack car, they keep loosing their heads!!
flyingkiwi
posted on 17/4/04 at 11:33 AM Reply With Quote
The majoy snag I've had with pop's is that they work loose after a bit of vibration. Resulting in a pain in the ass spinning rivet to remove. Sugest a blob of araldite or something similar to hold em in position.
I can get hold of countersink rivet's if anyone is interested. Having just Disbanded my beloved sea harrier squadron I've found a secret stash of countersink 3.3 and 4mm rivet's of perfect size. Loads available!
Give me a shout if you want some and I will see what I can sort out next week
Chris
It Runs!!!!! Bring on the SVA!
