Author: Subject: widening scuttle
Miks15
posted on 15/12/09 at 05:26 PM Reply With Quote
widening scuttle
I need to make my scuttle a fairbit wider. Whats the best way to go about doing it?
Its an MK indy scuttle.
My thought was cutting it down the middle, and screwing some ally strips into the sides of it to hold it together and then fill in with fiberglass.
Can anyone tell me the best way to do this? And how i would keep the shape of it aswell?
Mikkel
blakep82
posted on 15/12/09 at 05:29 PM Reply With Quote
the way i was told to do things like this, was rivet aluminium sheet to the OUTSIDE of the piece so it makes the right shape, then fibreglass the inside. the ali is then taken away to leave something almost the right shape for finishing, sanding and filling.
thats the theory anyway...
________________________
AdrianH
posted on 15/12/09 at 05:31 PM Reply With Quote
Have a look here on this site, it may give clues.
http://www.kineticvehicles.com/superscuttle.html
Adrian
Why do I have to make the tools to finish the job? More time then money.
Miks15
posted on 15/12/09 at 05:41 PM Reply With Quote
My plan was to leave the strips of ally on the inside to add a bit of strength on the join. Whcih will mean that my fiberglassing wont be as important.
I was thinking of doing the cereal box idea that i saw Mr Whippy do (i think it was him) when he widened his cycle wings, do you think this will work?
Triton
posted on 15/12/09 at 06:28 PM Reply With Quote
Easy...make a thin mould over the centre of the scuttle, once cured you can then pull it off and cut your scuttle in half. Fix the mould using double sided tape and clamps to desired width and gel and lay up from inside......'tis a doddle really
www.tritonraceseats.com
www.hairyhedgehog.com
Miks15
posted on 15/12/09 at 06:46 PM Reply With Quote
You make it sound so simple... its as if you done it before!
What do you recomend making the mold out of? And what wax will i need to ensure the mould pulls off?
blakep82
posted on 15/12/09 at 06:53 PM Reply With Quote
good question!
i want to make a mold of a diff cover for a later project.
can you make a list of all the ingredients i need to buy to make a mold too?
twybrow
posted on 15/12/09 at 07:32 PM Reply With Quote
CSM (Chopped strand mat) - comes in different areal weights (weight per unit area). 300, 450, 600gsm. I prefer working with 450, but you might not.
Resin - for tooling, go for an isophthalic polyester (lower shrinkage and higher heat distortion temperature). For general purpose orthophthalic resin.
Catalyst - normally comes with resin. Summer and winter varieties available.
Gelcoat - lots of choices (tooling, flowcoat/topcoat, uv resistant etc). General purpose will be fine, or buy tooling gel if it is for a mould.
Wax - you should add a small amount to the first coat of gel (working from the inside), to stop the surface being tacky - makes sanding a lot easier!
Mould release - at home, a tin of Mirrorglaze or similar beeswax is good. Alternatively, chemical semi-permanent relase agents (Freecote, Zyvax etc).
Then for mould making, wooden battens to glass in to stiffen the mould. Mixing pots. Paint brushes. Paint rollers if doing a larger area. Paddle/bristle roller for getting the bubbles out. Polishing rags. Acetone to clean up with.
I think that's about it.....!
Triton
posted on 15/12/09 at 08:19 PM Reply With Quote
Normal general purpose resin will do to make the mould, 3 or 4 layers of 450g matt.
Make the splash mould wide enough so you can use it as a clamp to allow the two sides to line up. Make sure it's as flat as possible to the old scuttle as gel will bleed thru.
It is easy honest, just a tad smelly and messy
RK
posted on 16/12/09 at 02:00 AM Reply With Quote
http://picasaweb.google.com/lh/photo/gphlyTQdcyqFp_CSUcmFzg?authkey=Gv1sRgCLfsoZrNyoKG4QE&feat=directlink
http://picasaweb.google.com/lh/photo/LAos3MfSBs-NGyfliRy_Ew?authkey=Gv1sRgCLfsoZrNyoKG4QE&feat=directlink
http://picasaweb.google.com/lh/photo/u78wAEbHftDKmScGwaZF2A?authkey=Gv1sRgCLfsoZrNyoKG4QE&feat=directlink
As per Kinetic Vehicles instructions. I used cello tape over the gap and turned everything upside down, and glassed in the gap. Simple. I have screwed up a lot of things on this build, but this was actually quite easy. I didn't use the part because I didn't like the bump where the windscreen goes, but it may find its way to another build that my wife doesn't suspect yet.
[Edited on 16/12/09 by RK]
