Author: Subject: Windscreen
Alan M
posted on 9/1/10 at 04:28 PM Reply With Quote
Windscreen
How should the windscreen frame be attached to the supports: salf tappers? Rivets?
posted on 9/1/10 at 04:34 PM Reply With Quote
I drilled and tapped mine, make sure you take the glass out !
Dave Bailey
posted on 9/1/10 at 05:02 PM Reply With Quote
Yep I did the same....
mangogrooveworkshop
posted on 9/1/10 at 05:03 PM Reply With Quote
how thick is your uprights?
RK
posted on 9/1/10 at 05:33 PM Reply With Quote
Drilled and tapped. Kintetic Vehicles can show you what to do. I had to ditch his frame (costly as it was) because it was too narrow and looked "bad". I ordered one from GBS, and with Mango's help, put it together.
http://www.kineticvehicles.com/windshield.html
[Edited on 9/1/10 by RK]
whitestu
posted on 9/1/10 at 06:07 PM Reply With Quote
My Caterham screen has rivnuts in the frame.
Stu
mangogrooveworkshop
posted on 9/1/10 at 06:20 PM Reply With Quote
I do them with captive studs that are flush inside and have a dome on the outside.
Alan M
posted on 9/1/10 at 06:46 PM Reply With Quote
Thanks for all the help. I guess as long as I miss the glass it doesn't really matter. I'll measure the uprights and frame tomorrow. I bought them from danozeman and I think they came from GBS
