Author: Subject: ALI SHEET
RAYLEE29
posted on 19/1/10 at 10:27 AM Reply With Quote
ALI SHEET
Hi, looking for ali sheet to make some panels im in poole dorset best prices so far are £46 for 5251 and £40 for 1050 from different suppliers. so is 5251 better or do i go for the cheapest?
also does anyone know of a cheaper supplier near me pls
thanks in advance
Ray
ps this is for 1.2mm is this a good thickness to use for the main sides?
tegwin
posted on 19/1/10 at 11:09 AM Reply With Quote
For non structural side panels... I would be looking at .6mm lighter and cheaper
www.verticalhorizonsmedia.tv
boggle
posted on 19/1/10 at 11:19 AM Reply With Quote
i prefere 5083 which is marine grade....
6082 is good for polishing but doesnt cold form without fracturing but 5083 does....
u2u me for details
MikeR
posted on 19/1/10 at 11:20 AM Reply With Quote
i wouldn't use 0.6mm, ever time a fly farts in the general direction you'll get a dent.
I've got 1.2mm 1050, plastic covered on one side for 25 quid, ex vat about 3 months ago.
I will struggle a little doing the rear panel (according to peeps on here).
[Edited on 19/1/10 by MikeR]
boggle
posted on 19/1/10 at 11:21 AM Reply With Quote
i used 1mm on my rear pannel with no problems so 1.2 would be ok....
u2u me for details
dan8400
posted on 19/1/10 at 11:29 AM Reply With Quote
UH OH
I've just ordered some 2mm to replace my original sides (due to engine change etc) couldn't remember what the original was and thought it'd do. Is it going to be too thick to bend??
Miks15
posted on 19/1/10 at 11:33 AM Reply With Quote
Originally posted by dan8400
UH OH
You might struggle with 2mm
dan8400
posted on 19/1/10 at 11:34 AM Reply With Quote
Bugger it! I just read this post and rang to change the order and they have already cut it into lengths. So i'll have to have it now
Daddylonglegs
posted on 19/1/10 at 11:42 AM Reply With Quote
UH OH
Maybe, but you'll have better side-impact protection
dan8400
posted on 19/1/10 at 11:55 AM Reply With Quote
hehe yeah maybe
will it be possible to bend? I know a guy with an industrial bender (steady). Will it break or bend?
Dan
thefreak
posted on 19/1/10 at 12:05 PM Reply With Quote
Get them to bend it for you?
I got the place I bought my side panels to put a |_| on one length and an |_ on the other so it should clip over nicely
MikeR
posted on 19/1/10 at 12:27 PM Reply With Quote
if you struggle to bend it yourself try annealing it first. (search on here / the web its been covered lots - involves blow torch and soap).
Angel Acevedo
posted on 19/1/10 at 03:25 PM Reply With Quote
Even if it doesn´t bend pretty, the extra thickness on the bend will allow you to file-sand-polish to a nice smooth finish.
HTH
PS: On the rear bends I mean....
Theshed
posted on 19/1/10 at 06:09 PM Reply With Quote
2mm sheet will require a greater radius than 1mm whatever the grade. I think you would be better off selling what you have bought and ordering again. 2mm would make a useful floor for somebody else.
steve m
posted on 19/1/10 at 06:48 PM Reply With Quote
" i wouldn't use 0.6mm, ever time a fly farts in the general direction you'll get a dent.
I will struggle a little doing the rear panel (according to peeps on here). "
i have just used 2mm on my rear panel and its fine. infact 100% better than when i did it first time in 1997
steve
