ianclark1275
posted on 23/1/10 at 03:41 PM |
is this too much sticking out of the bonnet? (latest pics)
Just fitted bonnet and had to cut a considerable amount out of it - plan is to make a cover / bulge for it, but suspect manifold angle is a bit too
steep?
measure twice, cut once, scrap it, start again.
ianclark1275
posted on 23/1/10 at 03:46 PM |
dad in photo - cant work computer!
mookaloid
posted on 23/1/10 at 03:49 PM |
Looks fine to me - lots of nice cold air getting to the carbs for better power
SPYDER
posted on 23/1/10 at 03:55 PM |
Looks fine to me too.
In the interest of getting a bonnet bulge game going I'll see your protruberance and raise you mine!
Geoff
[img][/img]
Humbug
posted on 23/1/10 at 03:56 PM |
I would make a scoop out of ali (unless your fibreglassing skills are up to much) to channel fresh air into the carbs while covering up the sticking
out bits.
Ben_Copeland
posted on 23/1/10 at 04:20 PM |
I assume its not been IVA'd yet .... incase i dont think it'll pass ! Theres only a certain amount that can stick out of the bonnet. My
original k&N filter stick out less than that, and i had to remove and put mesh over the top of the carb.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
skinned knuckles
posted on 23/1/10 at 04:36 PM |
as above, too much protrudes for IVA front projections
A man isn't complete until he's married, then he's finished
bj928
posted on 23/1/10 at 04:59 PM |
how come you can't get little engines under bonnet when i can get a v10 under mine!!!!
now you see it.
now you don't, little bonnet bulge and everything clears,
Bluemoon
posted on 23/1/10 at 05:07 PM |
now you see it.
Not quite a book chassis though is it!.. Helps being in a V con-fig, cross-flow is always going to take up a fair bit of space with sidedraft carbs,
but it will be nice and light weight.
Dan
[Edited on 23/1/10 by Bluemoon]
bj928
posted on 23/1/10 at 05:14 PM |
the basic chassis is a luego viento and so is only slightly different to a book chassis from what i can tell, but yes the v does help a lot.
pewe
posted on 23/1/10 at 06:24 PM |
If you look in my archive you'll see mine which passed SVA.
However my concern (echoed by the guys at Eurocarb who supply Weber bits) would be what happens if it's hissing down with rain? There is a good
chance of the front carb ingesting water - i.e not a good idea.
As a temp. measure I've made a curved shield from ali. with folded edges which is attached by rivets and sealer & sits in front of the
carb.
I'm also in the process of making a bulge from glassfibre to cover the carb completely.
I used cardboard covered in tank-tape for the buck, then plaster of paris and scrim for the mould before smoothing and waxing the interior prior to
laying up the resin and mat. It's not a perfect way to make a bulge but means you have the shape you need which can then be filled using filler
paste, attached to the existing bonnet and painted.
HTH. Cheers, Pewe
PS Other thing to consider apart from water ingestion is if it's an all-year-round car the carbs could well ice up in cold weather. My
preference would be for a fully enclosed bulge meaning the carbs draw air from under the bonnet - duct some cooler air from further forward if
that's a requirement.
[Edited on 25/1/10 by pewe]
dlatch
posted on 23/1/10 at 07:12 PM |
Dan
now run that V10 on side draught webers then check if it will clear the bonnet
rickys2000
posted on 23/1/10 at 07:25 PM |
and the viento is about 4" wider than a locost chassis
loggyboy
posted on 23/1/10 at 10:32 PM |
pop somthing like one fo these cut in half over them- even if its just for IVA.
[Edited on 23/1/10 by loggyboy]
ianclark1275
posted on 23/1/10 at 11:01 PM |
Many thanks for the replys
question now is:
Make a cover out of mesh or ali or fiberglass?
the old boy suggested and a simple ali cover with mesh on end.
as its his car - (with my help of course!) i think a ali cover should do it.
it was backfiring like crazy today - really needs a tune up - think boggy should sort it.
Angel Acevedo
posted on 24/1/10 at 11:44 AM |
Cloth Prefilter
ianclark1275
Besides whats been told before and seeing how close to wheel spray your filters will be, I would use cloth covers on top of the filters to aid keeping
them longer unclogged a little longer.
But that´s just me,,,
I am waaay tooo far from your stage.
spiderman01980
posted on 24/1/10 at 02:15 PM |
bj928 are you off your nut a V10 what litre is it and what kind of power is gonna pump out?!
P.S you have to take me out in it when you finish it!
