FASTdan
posted on 24/1/10 at 08:55 AM |
4 port vacuum take-offs - collector dims?
I recall someone mentioning that typical dimensions are available for a vacuum collector unit when trying to run a MAF system but with 4 individual
ports, 40's, bike carbs etc.
Does anyone know where that is on the net? searching google mostly brought up dysons lol.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
will121
posted on 24/1/10 at 09:58 AM |
do you mean for a MAP sensor link here for one for
megajolt system
Angel Acevedo
posted on 24/1/10 at 12:20 PM |
Exhaust Air injection Tank
I deleted the emissions exhaust pump and associated hoses-hardware from a 5.0 Ford Mustang (Mexico) and it had a .5 lt more or less tank, you may be
able to salvage one from a car equipped with such a system and use it as a plenum with a couple of fittings and vacuum hose.
iank
posted on 24/1/10 at 12:27 PM |
I've read about people using modified fuel filters for the job.
Don't know how well they work compared with other sizes.
Anonymous
ashg
posted on 24/1/10 at 01:27 PM |
when i was playing about something the size of a bean can worked nicely.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
snapper
posted on 24/1/10 at 02:12 PM |
My Collector is a simple 6" length of 10mm copper tube, seems to work OK but i understand that the Megajolt recomendation is a box 2 x 2 x 3
I eat to survive
I drink to forget
cliftyhanger
posted on 24/1/10 at 05:15 PM |
I reckon a bit of 22mm copper, cap on each end (though drill the fitted one before fitting the other if soldering!) and 4 mig tips in one end, one in
the other. Perfect, neat and easy.
kylerichmond
posted on 21/2/10 at 01:36 PM |
What type of tips would i need and where can i get them?
