smart51
posted on 28/1/10 at 08:47 PM |
Paint Nightmare
I'm repainting the plastic bumper skirt of my Cappuccino but am having no end of reaction problems. This is now the third time I've had
to sand off paint that I've applied due to what I think are called crows feet.
I cleaned the panel with soapy water then wet sanded it with 400 grit. when it had dried I sprayed it with a polyester spray filler. The paint
seemed to shrink back leaving loads of "cracks" showing the original paint below. I sanded this off and let it dry. Next I tried some
Halfords plastic filler primer in an aerosol. I thought Acrylic might have better luck than polyester. Not much. Anyway, I had another go with some
plastic adhesion primer, which did work a bit better but I still have 2 areas that I've had to sand right back. What do I do?
skinned knuckles
posted on 28/1/10 at 08:56 PM |
got me stumped. if pap don't work, i have nothing to suggest
A man isn't complete until he's married, then he's finished
MikeR
posted on 28/1/10 at 08:58 PM |
what state is the bumper in, i'm wondering if there could be some wax on it stopping adhesion.
Steve Hignett
posted on 28/1/10 at 08:59 PM |
It's not the right thing to do, but you can get past it by building up layer upon layer of dust coats...
MakeEverything
posted on 28/1/10 at 09:01 PM |
I had the se problem on a M/C front fender.
I think i used primer filler in the end, but it never did work too well. I think its something to do with the silicon in the plastic reacting with
the paint.
I know that paint doesnt like silicon, and the smallest amount can ruin a paint shop.
Kindest Regards,
Richard.
blakep82
weird
if it is the paint shrinking (for whatever reason) could you spray a few really really light coats (dusting basically) first to allow them to do any
shrinking first, and then once they're on, do you proper colour coats?
also, have you been wiping the bumber with any of those prep cloths first, silicone remover, or thinners first?
________________________
jacko
posted on 28/1/10 at 09:03 PM |
Has it had back to black on it or something like that ?
oadamo
posted on 28/1/10 at 09:15 PM |
dont wet sand before you paint and dont use soapy water.
adam
plentywahalla
posted on 28/1/10 at 09:30 PM |
Try 'BARCOAT' its a barrier paint that prevents any reaction between layers like silicone impregnation or incompatable solvents.
You can even apply 2k over single pack paints with it.
ashg
posted on 28/1/10 at 09:32 PM |
use a 2k primer and leave it for 2-3days before you go for the base. simples.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
smart51
posted on 28/1/10 at 10:14 PM |
Thanks guys. The bumper was in good condition save for being peppered with stone chips. It had been waxed about 6 months ago but nothing more
since.
I've put a dust coat on it and will check put another on in a few minutes. If it looks bad in the morning, I'll go to the paint shop on
the way home from work for barcoat or similar. I'd hoped to be finished already and have a couple of days for it to harden before fitting it
back to the car on Saturday.
smart51
posted on 29/1/10 at 08:01 AM |
Well that didn't go well either. 2 mist coats last night before bed then one in the early hours thanks to insomnia. This morning there are
fine cracks where the large ones were yesterday. Jawel paints are not too large a detour on the way home. Lets say what they come up with.
posted on 29/1/10 at 08:42 AM |
I'd still suspect the wax preventing adhesion. I'd give it a good talking to with a sanding block and have another try.
I'm not expert but hey
russbost
posted on 29/1/10 at 10:39 AM |
It's not a wax or silicon problem - they cause "fish eyes" not crazing which you've got. Most likely cause is that the bumper
has been painted with someting like an acrylic/synthetic in the past, tho' sometimes reactions just seem to happen for no obvious reason.
I wouldn't recommend the "dust coats" route because you may be fine until you put a final wet coat on to get a shiny finish &
will all happen all over again.
You need an alcohol based sealer, which I believe Barcoat which has been mentioned is an example of. However, to be safe you'll need to seal the
whole bumper, otherwise, your sealer will go on fine, but when you put anything else over the top of it it may well react around the edges of the
sealer coat!
smart51
posted on 29/1/10 at 11:05 AM |
quote: Originally posted by russbost
Most likely cause is that the bumper has been painted with someting like an acrylic/synthetic in the past
In places there is a white layer between 2 layers of red so I now suspect it has been repainted before.
to be safe you'll need to seal the whole bumper, otherwise, your sealer will go on fine, but when you put anything else over the top of it it
may well react around the edges of the sealer coat!
Good tip.
Angel Acevedo
posted on 29/1/10 at 11:40 AM |
I am by no means an expert but I have had the problem before.
- Wet sand
- Wash thoroughly with heavy duty degreaser.
- Sun dry ??
-Tack rag,
-Light coat of adhesion promoter
-let dry
-A couple, maybe more thin coats high build primer.
- Key in with 600 grit.
-tack rag,
color
-color sand
Clear coat.
-let dry a couple of weeks,
-polish and wax
lot of work, but must do the trick
smart51
posted on 29/1/10 at 09:10 PM |
UPOL Barcoat is now my best friend. Mind you there were a couple of places where I had to give it a second coat. It now has a coat of filler primer
which has not reacted. Hopefully it will stay that way for the rest of the job. Thanks everyone for your help.
