Author: Subject: Tube bending
pewe
posted on 9/2/10 at 12:19 PM Reply With Quote
Tube bending
Hi, I want to extend the existing roll-bar by welding on a couple of hoops which will then be braced at the back down onto the existing stays.
Current roll bar is 40mm diam.
Overall length of tubing is approx. 700mm/hoop (needs a bit of straight to join existing on one side).
Any suggestions as to what type/thickness of tube to go for and likely cost to supply it and bend to a 170mm I/D?
Thanks in anticipation, Pewe
MikeR
posted on 9/2/10 at 12:43 PM Reply With Quote
I'd suggest speaking to welderman if you can weld it on yourself / can't get your car up to Chorley.
Quite a few people have been happy with his work and he will supply bits of metal bent to your plans.
locoboy
posted on 9/2/10 at 02:02 PM Reply With Quote
I have been trying to get hold of him to quote me on a few hundred quids worth of work and cant get a price out of him...............
Locoboy
procomp
posted on 9/2/10 at 07:47 PM Reply With Quote
Hi
Last i heard Joe was of on a skiing holiday. Have seen his pictures on FB so he may still be out there maybe.
Are you sure you really want to add additional hoops to an existing bar. It is certainly not a recommended way of gaining the extra height. May be worth just getting Joe to quote on a new hoop to the higher height.
Cheers Matt
welderman
posted on 9/2/10 at 11:59 PM Reply With Quote
Been here there and everywhere mate, even managed a track day or two, trip to kent and work ! lol, i thought i emailed you a price, will check my sent messages tomorrow.
Joe
Thank's, Joe
I don't stalk people
welderman
posted on 10/2/10 at 12:02 AM Reply With Quote
Originally posted by procomp
Hi
Cheers Matt
Ta Matt, yep skiing of FB lol.
Pewe, i may have a rear roll hoop left over from the last lot i made, send me some sizes and i will check for you
Joe
Thank's, Joe
welderman
posted on 10/2/10 at 09:19 AM Reply With Quote
u2u on price
Joe
Thank's, Joe
