omega0684
posted on 9/2/10 at 07:03 PM |
Search Your Brains!
right guys i've been searching for hours and im struggling to find any reasonable prices, i've looked at the obvious people, Quaife, BGH,
SP Components, Raceline but they all want far too much
im after a Heavy Duty type 9 box, to take up to around 210 Bhp and at least 170 ft/lbs
im looking for ratio's in the region of 2.39, 1.54, 1.21, 1.0, 0.87/0.93.
do any of you know people who work for 'X' company that can get parts on the cheap or can get discounts etc etc. or is it going to be a
case of im going to have to find extra depth in my pockets?
oadamo
posted on 9/2/10 at 07:12 PM |
be easyer and cheaper just to change the box with a bellhousing to suit your engine.
adam
t16turbotone
posted on 9/2/10 at 07:19 PM |
How big is your budget alex?
r1_pete
posted on 9/2/10 at 07:24 PM |
Isn't the diesel P100 pickup variant of the type 9 about the strongest? try searching the commercial breakers for one of thise...
snapper
posted on 9/2/10 at 07:32 PM |
The P100 box ratios are diabolical, best ratios in the Type 9 is the V6 but nowhere near what Alex wants.
No easy solution but the Cosworth T5 box will take the strain, has 2.9 first
I eat to survive
I drink to forget
iank
posted on 9/2/10 at 08:13 PM |
Another vote for a T5, gives some headroom if you get really greedy for power
Anonymous
omega0684
posted on 9/2/10 at 08:16 PM |
a T5 with those sort of ratio's is on the verge of 4 figures! well out of my reach. and then i would have to get bellhousing etc as well!
mr T
posted on 9/2/10 at 09:18 PM |
Have a look Here
flak monkey
posted on 9/2/10 at 09:25 PM |
Why are you being so specific over the ratios alex?
They are all slightly lower than any of the std type 9 boxes, so you could just change the final drive ratio to 3.38:1 (if you have 3.62 at the mo)
which would have a similar effect...
I know a few people running standard (totally unmodified) type 9's on turboed cars pumping out 300+bhp and they havent broken yet.....
I rebuilt my box with a HD gearkit from BGH which gives a much longer first than std....and they are then rated to 240bhp and 200lbft...
Sera
http://www.motosera.com
paulf
posted on 9/2/10 at 09:37 PM |
Its only really first gear thats a problem due to being to low, I would like a higher first gear but the money would be better spent on tyres or
suspension in my book.
A standard type 9 is ok in a light car as large amounts of power just spin the wheels and limit the torque the box is subject to.
Paul.
Dan.
posted on 9/2/10 at 09:53 PM |
Interesting...
I have been looking for a gearbox for my 300HP 400lb/f but the only thing i could find with half decent ratios and enough strength was a T5 box. is a
type 9 really ok for this kind of power in a light weight car like an Indy, if it is it solves my bell housing issue as I can buy an adaptor plate for
a type 9 box.
Incidentally just thinking about it,I presumed they T5 and the type 9 gearboxes have different mountings, but maybe they are the same?so I could use a
type 9 adaptor plate on a T5 box....?
ps sorry for the thread hijack!
[Edited on 9/2/10 by Dan.]
omega0684
posted on 9/2/10 at 09:54 PM |
quote: Originally posted by mr T
Have a look Here
if any of you have the ability to get in touch with 'pete f' the poster of the above link, or the ability to post on the WSCC forum can
someone send pete a PM/U2U or post a link to this thread on Pete's thread, either way to get him to contact me as im not allowed to post in that
section as a new member on the WSCC Forum (which is a bit pants!)
cheers
flak monkey
posted on 9/2/10 at 09:58 PM |
a type 9 box.
What engine makes 300bhp and 400lbft?! Sure thats not 400Nm (295lbft)!?
Sera
Dan.
posted on 9/2/10 at 10:02 PM |
a type 9 box.
Thats what I meant lol...I was up at 6am brain not functioning!
omega0684
posted on 9/2/10 at 10:05 PM |
i've been up since 4am! off to bed now though!
Jenko
posted on 10/2/10 at 08:16 AM |
I have a standard T9 running 203bhp and 190lb/ft...Never had any issues, and I do a few track days......However, it is standard and the ratios are
pants......
I'm a member of the WSCC so if you want me to drop Pete a PM, then give me a shout.
Of course, reality is there is no 'Cheap' way of doing what you want....It's quite an expensive mod, but BGH would would get my
vote.
MikeR
posted on 10/2/10 at 08:32 AM |
have you contacted tran-x - at least with them you could save postage and nip to B&Q at the same time ![](/images//smilies/smile.gif)
t16turbotone
posted on 10/2/10 at 04:33 PM |
Alex have a look here mate...
http://www.hi-gearengineering.co.uk/ford.htm
tony
mr T
posted on 10/2/10 at 09:27 PM |
Have a look Here
Have a look again
Tony
Dave Ashurst
posted on 11/2/10 at 05:36 AM |
Alex
If you used my gearbox chooser spreadsheet then beware.
I wrote it only to help me choose between gearboxes I could actually find (i.e. ones within my budget) rather than to specify theoretically ideal gear
ratios from scratch. That would be big budget territory for sure, Mr Brawn!!
Note that yes, the data library in the spreadsheet does contain some very expensive options - not ones I can afford either. I just cut and pasted a
load in to play with.
I suggest you'd be better off deleting the library data, finding a selection of gearboxes you know you can afford and writing those ratios in.
Then use the spreadsheet to get an idea of which will feel best through the gears in your car. (disregard the acceleration from standstill to about
20mph, it doesn't do clutch slip so the very low speed curves are wrong. Alternatively use "Car Test" which gets it right, and then
modify the ratios in that).
D
omega0684
posted on 12/2/10 at 11:52 AM |
Mr T & Jenko: Thanks Guys after a chat with Pete last night im soon going to have dig a rather large hole in my pocket!
procomp
posted on 12/2/10 at 12:28 PM |
Hi
The only way you'll get those ratios at decent money is in a SH Quaife or tranex box. But if you gonna go looking for specific ratios. Then why
not the 2.04 first. rather than the 2.39 . The 2.39 is not much better than a rocket first. Most would opt for the 2.04 ratio. And most boxes that
come with either of those first gear ratios will come with the 0.93 5th as well.
Good luck with the search.
Cheers Matt
