dan8400
posted on 22/2/10 at 07:49 PM |
Fiberglass question
I am part way through converting from pinto to zetec. Pinto had a single down draught carb so i made a hole in the bonnet and got a K&N filter. My
zetec is on bike carbs so i a) need hole/holes in a different place and b) need to fill the hole left by the K&N.
Can it be done? And how do i go about matching the gel-coat? Or do i just have all the panels re-sprayed?
Kinda hoping there is a 'locost' solution. BTW it's a tiger supercat (and they want a huge amount of money for another bonnet)
Dan
RichardK
posted on 22/2/10 at 07:59 PM |
As much as I hate to say it I think I'll have to vote for a new bonnet if its not faded that much, if it has then I'f fill all the holes
with fiberglass and paint the lot.
Rich
Gallery updated 11/01/2011
dan8400
posted on 22/2/10 at 08:14 PM |
Do you think it'll be more cost effective to have a new bonnet? Around 200 quid i reckon IIRC
Or new paint job? I really can't decide. Don't really have the money for either right now if i'm honest
Dan
YQUSTA
posted on 22/2/10 at 08:25 PM |
You could fill the hole with some mesh and use it as a bit of extra cooling until you can afford a new bonnet or to do the repair work properly.
"If in doubt flat out"
Colin McRae
RichardK
posted on 22/2/10 at 08:35 PM |
What about putting a bulge over it, not this one as I think its a bit big but similar
Linky
Rich
dan8400
posted on 22/2/10 at 08:36 PM |
Great idea, i have some mesh left over from the grille locost (albeit temperary) solution
Dan
dan8400
posted on 22/2/10 at 08:38 PM |
Another good idea richard. Thank you.
What about cutting the same hole on the other side and mesh-ing both. So at least it's symetrical.....?
Temporary until i can afford new bonnet. Good for cooling too
Dan
stevegough
posted on 22/2/10 at 09:13 PM |
Whatever you do, be careful not to make a mesh of it!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
dan8400
posted on 22/2/10 at 09:22 PM |
Hehe
Hey - That's Journey!!!
jacko
posted on 22/2/10 at 10:01 PM |
How about
Cutting a piece of aluminium about 12mm bigger then the hole type it on over the hole with strong type
Turn the bonnet over fibre glass from the inside add pigment if you like .
when dry remove ally fill and paint
Jacko
