howard mann
posted on 28/2/10 at 11:31 AM |
bodywork and exterior
hi is it ok to use 1.5 mm ally on floor on out side of chassis for ron champ locost cheers or would it be better thicker
[Edited on 28/2/10 by howard mann]
Snuggs
posted on 28/2/10 at 11:33 AM |
Well it's in the right section
[Edited on 28/2/10 by Snuggs]
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
oadamo
posted on 28/2/10 at 11:35 AM |
adam
big_wasa
posted on 28/2/10 at 11:38 AM |
fine on the sides some use thinner but I like a bit more under my arse
howard mann
posted on 28/2/10 at 11:44 AM |
thicker must be then cheers
hicost blade
posted on 28/2/10 at 12:04 PM |
Im using 1.2mm (18 gauge) for my floor , as reccomended by a Westfield/Locost specialist, It has to be NS4 though!!!!!!
MikeR
posted on 28/2/10 at 12:11 PM |
i've not done my sides yet but general wisdom seems to be to use 1.2mm ali on the sides - so thats what i've got.
big_wasa
posted on 28/2/10 at 12:34 PM |
I will say 1.5mm is a lot harder to work with than 1.2mm.
I did the tunnel sides and rear bulk head in 1.2mm. I did the scuttle in 1.5mm.
I did the floor in tank armour ie 1.5mm steel
1.5mm would be fine all around if thats what you have. Depends what you will use the car for. On the road I would like a bit more than 1.5mm of alli
between my bits and the tarmac.
Bluemoon
posted on 28/2/10 at 12:56 PM |
2mm ali (don't know grade its as supplied by mk) on mine.... I even feel that should be thicker, still as far as i know all indys are 2mm..
Dam
The Black Flash
posted on 28/2/10 at 08:49 PM |
Just FYI, my Dax came with 1.0mm ally for everything.
howard mann
posted on 28/2/10 at 09:00 PM |
cheers once again think floor 2mm rest 1.5 god i like this site
