Author: Subject: Tunnel Design
Daddylonglegs
posted on 3/3/10 at 09:39 PM Reply With Quote
Tunnel Design
What views do you guys have on making the tunnel cover as a single piece. i.e. like a centre console in a regular tin-top?
I am thinking of making it as one and attaching it at the base so the top stays nice and clean (and IVA friendly)
JB
Ben_Copeland
posted on 3/3/10 at 09:59 PM Reply With Quote
Dont see why not... Depends if you want it to go under the dash as all one piece or not...
One piece tricky but not impossible, two piece should be fairly easy.
Structuring at the side of the seats could be tricky ( well unstructuring anyway)
[Edited on 3/3/10 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
YQUSTA
I really like te idea I have seen some that look like they were done like that i think there was an MNR one.
My preferance is a nice 1 piece carbon one not to everybodys taste but the look I want.
"If in doubt flat out"
Colin McRae
Nash
posted on 3/3/10 at 10:05 PM Reply With Quote
I made mine from Carbon look ABS in three pieces top (one piece) and the two sides. I'm struggling to get an edging trim finish I like with rounded 2.5mm corners that doesn't look agricultural.
Also when I was checking from "sharp edges I found my handbrake and gear lever trim pieces were non compliant so I need to reconsider the whole tunnel finish. I did see the MNR rounded unit (I think it was MNR) and that looks ok but not sure it would fit an Indy?
.........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
Daddylonglegs
posted on 3/3/10 at 10:13 PM Reply With Quote
I'd like to make it out of FG but not sure my skills are up to it.
YQUSTA
posted on 3/3/10 at 11:30 PM Reply With Quote
The only way is to try.
SO what if you make a mess of it at least you can learn from what you did wrong and then make it better.
From what I have read and seen on the web it's all about prep work on the mould, once you have a good mould you can make more than 1 so a few cock up's won't be the end of the world.
You never know you might just be good at it and be able to produce them to sell a few and make a few quid doing so.
I say try it.
Colin McRae
Davey D
posted on 4/3/10 at 07:09 AM Reply With Quote
The MNR centre tunnel is a 1 piece design that drops over the steelwork underneath
Daddylonglegs
posted on 4/3/10 at 08:18 AM Reply With Quote
Thanks for the encouragement guys, think I'll just give it a go
