andrew-theasby
posted on 4/3/10 at 11:09 PM |
reccomend a lacquer, is 2k dangerous?
Is 2k lacquer as dangerous as it sounds? Theres plenty of people selling it on ebay, i thought it was banned. If so what is a good type of
lacquer/clearcoat to use its going over an epoxy resin finish, and i want one with a high build. I found
this but its 2k, what do you think
skinned knuckles
posted on 4/3/10 at 11:14 PM |
that is what i use when i cant be bothered getting the compressor out for the smaller jobs. just use a good quality mask (at least the ones with the
filter cans on the side)
A man isn't complete until he's married, then he's finished
austin man
posted on 4/3/10 at 11:15 PM |
Nah its as safe as cyanide can be. You do need a good mask air fed realistically
andrew-theasby
posted on 4/3/10 at 11:22 PM |
Is 2k fuel proof too? Thanks
skinned knuckles
posted on 4/3/10 at 11:33 PM |
you dont want to leave petrol (or any other solvent) sitting on any paint/clearcoat finish but it will do as well as any in my experience.
andrew-theasby
posted on 4/3/10 at 11:37 PM |
Ye, sorry, i didnt mean completely fuel proof, but if you splash it etc...
Ben_Copeland
posted on 5/3/10 at 06:36 AM |
Be careful tho, its still poisionous. Whatever mask you use make sure its got a good filter... Airfed are obviously the best. If you start to smell
the paint, GET OUT !
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
ashg
posted on 5/3/10 at 08:57 AM |
be carefull with 2 pack paint it has isocyanate in it which is a really nasty chemical. isocyanate can be absorbed into the body through any mucus
membrane. basically meaning breathing it in is pretty bad. what people dont realise is that you can absorb it through your eyes!! and even skin if you
are sweaty.
effects can range from headaches, vomiting, stomach cramps, lesions and skin burns, laboured breathing. studys believe long term or high exposure can
lead to cancer
be warned
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
andyw7de
posted on 5/3/10 at 08:58 AM |
I painted my BMW with 2 pack paint, I used a mask but it wasnt air fed, Even in a good ventillated workshop i was feeling crap for days after.
Same as rubbing off the laquer without a mask its not nice
wilkingj
posted on 5/3/10 at 10:07 AM |
DO NOT PUT YOURSELF AT RISK.
Believe me you really DONT want to use this stuff without the correct safety precuations.
You body can have strange reactions to ANY chemical or Biological contaminant.
I breathed in Blue/Green Algae when cleaning my drive with my pressure washer.
My immune system saw this as an attack, and reacted by attacking eveything in sight, namely my nervous system. My immune system attacked my nerve
receptors and completely paralysed me.
I was in hospital for 14 days and off work for 6 months learning to walk again etc.
that was 15 years ago. I never fully recovered, and its blighted my life ever since.
PLEASE do not think "It wont happen to me"
PLEASE take ALL the correct precautions when using these paints and preparations.
These safety measures are there for very good reasons.
This is not a case of Health and Safety Bollox... Its a REAL risk to your health.
My problem came from a bio hazard.
Ask yourself... WOULD I swallow a cyanide capsule if I didn need to? The answer will tell you how to handle 2 pack paints which produce it, and other
harmful things like solvents / thinners etc etc.
Best Regards
Geoff
http://www.v8viento.co.uk
MakeEverything
posted on 5/3/10 at 10:12 AM |
Spraying this kind of paint anywhere other than in a spray booth, is potentially deadly. Not least for the fumes (not smell) which you or passers by
could breathe in, but for the explosive vapour as well.
Dont do it.
Im going to use cellulose, but will see if i can get to a spray booth locally.
Kindest Regards,
Richard.
MikeR
posted on 5/3/10 at 12:43 PM |
just been reading today on the mig welding forum about this - very interesting read. My summary .... be so very careful you really want to pay someone
else to take the risk.
andrew-theasby
posted on 5/3/10 at 06:16 PM |
is it still dangerous once its dried? Ie to rub it down, or is it just the same as any other paint dust then? Thanks for the warnings
Brommers
posted on 6/3/10 at 05:36 PM |
No, once it's dried there are no isocyanates left since they've all reacted to form polyamine chains.
Before then it is seriously nasty stuff, however. I use it, but I've got an air-fed mask fed by a separate compressor with an external air
feed, full Tyvek overalls and a dedicated spray booth with powered ventilation in the middle of nowhere.
If you're not confident that you're aware of the risks to yourself and to others and have taken all necessary steps to mitigate or
eliminate those risks then I'd advise against using 2k paints.
boggle
posted on 6/3/10 at 06:34 PM |
i did a full colour change on my subaru the weekend before an event....in pearl....door shuts the lot....all in a booth, but i did it all without a
mask...
spent the next week with cyanide poisoning....worst week of my life.....
one effect i had was my gums swelling up and popping.....
u2u me for details
Neville Jones
posted on 7/3/10 at 12:14 PM |
There's so much of this misinformation about, it's getting stupid.
You think the fumes from cellulose are less explosive than 2k? No way!! They'll go bang with the best of them.
For a small job, like a 7, it's ok to use 2k. Just as long as you use a decent mask. You'll need a few new filters though. Make sure the
area is well ventilated, and fumes are not blowing into your neighbours, and you're fine.
Yes, people have been known to die from using 2k, and I know of two instances personally where 2 guys working in a large well known boatyard in
Florida died within two days after spraying a large yacht. They did it in a fully enclosed shed, in hot weather, with no masks, and the paint was a
particularly potent new formulation. The other was boats as well in Italy, and six guys went down, with one dying, after doing a similar thing.
The paints have changed since then, but are still noxious.
Just leave out all the H&S shite, and the 'prophet of doom' stuff, and use a bit of common sense!
After all that,
Nev.
